93 3.4l dohc mod ?'s
  • grandprixgtp_93
    • Feb 2010
    • 75
    im currently looking to upgrade me 93 gtps LQ1 does anyone know some easy cost effective mods for this engine? if so i could us some help i dont want to go to extreme as my car is the 4t60-e auto trans and it cant handle to much power. please let me know if you have any advice.
  • RedZMonte
    • Feb 2004
    • 1378
    what do you have done to the car now? if its stock then most people start with Air intake, Exhaust then move to suspension... it all depends on what you want to spend.. Everyone here will recommend you have all your mant. done 1st.... T-belt, tune up, trans service, fuel filter, ect...
    i have just about every mod you can do without tearing into the engine... Turbo, intake manifold swap, OBDII, suspension... only thing left for me to do is turbo headers, P&P heads, custom cams.... all the expencive stuff lol... but im making 331hp to the wheels on my original 145K Mile 4T60-e w/o a problem.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Not doing stoplight to stoplight racing will help a FWD auto live longer. Also 1 wheel peels are a big no-no too.
      • grandprixgtp_93
        • Feb 2010
        • 75
        the car is bone stock ive only had it about a month now i have the engine pulled out of the car for a rebuild im bringing the block in to put it in a hot bath and to have the main journals and cylinder walls honed and ridge reamed i have a specter cai that i made im just wondering what else is easy that i can do for cheap while the engine is out of the car that i could fine the parts fairly cheap and would be easy todo b4 putting the engine back in the car....what is needed for the 95+ intake manifold swap i hear that adds a good amount of power and can the heads and cam carrier set up be swapped also from the same engine so i can get some aftermarket headers they make for the 95 dohc 3.4L
        • grandprixgtp_93
          • Feb 2010
          • 75
          im building this car to run scca auto cross and to have some pep on the hwy.....how hard would a 5spd swap be
            Not very hard if you have a donor car. Mine was a matter of bolting the tranny in, moving the speed sensor wire in the main under hood harness from the passenger side to the drivers side, bypassing the P/N safety switch, replacing the firewall section (that bolts in) behind the pedals and knock the knock outs in the firewall out for the shifter cables. Oh, and grab a 5 speed chip, or order one from Ben. And for referance, the intake swap you want is 96+, the 95 intake is the exact same as 91-94- it's the 96 and 97 intake that is the larger runner intake.
            • grandprixgtp_93
              • Feb 2010
              • 75
              ok thank you for that info whats needed for the intake swap?
              • RedZMonte
                • Feb 2004
                • 1378
                intake swap right-up:
                http://60degreev6.com/content/9697_I...p_9195_Engines
                Shane "RedZMonte"
                • walterdude
                  Destroyer Of ALL THINGS!!
                  • Feb 2006
                  • 265
                  Could also play around with custom cam timing.. People report VERY good gains from the 6 and 6 cam timing...
                  Tom...
                  • grandprixgtp_93
                    • Feb 2010
                    • 75
                    whats the 6 and 6 timing? and would swaping my head for some 96 heads benefit i was looking into this so i could get a set of headers cuz i will be porting and polishing these heads at my school and would i need to get the cams and cam carriers from the 96 or would my original ones work....i have about a $4000 budget for this engine build so im trying to get every little bit i can b4 i have to put the engine back in
                      • 9187
                      http://60degreev6.com/content/Cam_Ti...re_Walkthrough
                      Scroll down to the bottom where it explains the different cam timings.
                        Your original cam carriers will bolt right down on 96 heads that will bolt right down on to your 93 block. Also the 96 intake will bolt to any of the cylinder heads, 91-97. Simple is good
                        • RedZMonte
                          • Feb 2004
                          • 1378
                          IIRC if you put the 96+ heads on the ports are larger but it becomes an interference motor.... I could be wrong but i thought that is one of the things i heard about the '96-7 heads.. I would just port your heads and do the '96 intakes... also if i remember the older cams are better then the '96 cams.... can someone confirm this?
                          Honestly i would keep your heads, replace the seals, port them, angle valve job and a good set of springs and retianers.. If you have more$$ WOT-Store sells light weight Lifters as well.
                          Are you making custom headers i read?
                          S
                          Shane "RedZMonte"
                          • grandprixgtp_93
                            • Feb 2010
                            • 75
                            no im not making custom headers i was goin to swap to the 96 heads so i could get a set of headers that are made for the 96+ heads cuz they have different exhaust ports
                            • mrl390
                              • Jan 2008
                              • 132
                              Are you looking at the MMS headers for the 96-97 dohc? Arent they like 1000 dollars? Dont even waste your money.
                              -Matt
