does anyone know where i can find a 2800 to 3200 stall torque converter
Torque Converter questions
Tags: None
If you can find an "FA" or "FB" GM converter they are rated at 2795 and 2760 RPM when used in rather low output 4 cylinder applications.
With even a slightly modded V6 you would be in the 3000+ range pretty easily.
OR you can contact me directly and I can get you a newly rebuilt one, however shipping may be expensive.
asylummotorports@yahoo.ca
I have a 2750 stall and I love it...1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
GM didn't make a 2750 unless it's something rather recent.Originally posted by HayesPerformance View PostI have a 2750 stall and I love it...
FA 2795
FK 2760
FB 2560
FC 2385
FZ 2375
FD 2095
Having that established, they will all be different (higher) with a modded V6!
Most of these are 4 cylinder models that we get to take advantage of.
I currently have an FA1B that has been "tweeked" and it's going to be somewhere around 3300.
With you running the FA I'm half tempted to try my PDQ one once again... just to see if I can figure it out... I never did run that setup at the strip, I was going all off of the butt dyno saying the bottom end felt weird.
It's not a Factory torque, lol
I should have said "I Installed" a 2750 Stall, it was a custom built torque, made more beefer then stock of course as well..1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
I actually haven't driven with this one as yet.Originally posted by 3400-95-Modified View PostWith you running the FA I'm half tempted to try my PDQ one once again... just to see if I can figure it out... I never did run that setup at the strip, I was going all off of the butt dyno saying the bottom end felt weird.
It's going in when I do the engine.
Billy took the whole thing apart again after the rebuild because he didn't like the 2-3 shift at WOT. When he put it back in, it's hanging on three bolts to save time taking the engine out.
But it WILL feel alittle strange on the street I imagine. I really don't care on this application.
I really should try it again then... The PDQ guy swore that I would be happy with that converter with what specs I gave him on my engine...
HRMMMMMM decisions decisions!
ok so where would i go to buy a fa torque converter to put in my car i need to know pretty fast my engine is almost assembled and i need to get it before i put it back in the car. also does anyone know iff the wbody exhaust from oem come with the down pipe section i was thinking about ordering it and i need to know if i need to fabricate a down pipe or not.
i know magnaflow makes a downpipe for the 1995-97 Monte carlo 3.4L dohc. that can be moddified to work with your 1st gen. (rear flange is different, thats about it). Or just have one made. I have seen some of thoes Magnaflow downpipes on ebay a few times cheap (VERY expensive if you buy from magnaflow, Stainless, mandrel bent and includes Cat and flanges.).
Check with some local transmission shops and look to see if there is a TQ converter place localy to you that rebuilds TQ converters, they should be able to tweek it.. I had a local shop to me build one for a few hundered, 3000 RPM stall... With my turbo setup i will force it up to about 5500 if i hold it long enough... Ive been to chicken shit to actually launch it at that rpm... only a couple 3K stalls, feels good
If it helps here is the guys that did mine. Good guys, done alot of business with them in the past.
Colorado Converters, Inc
159 Buckeye Ave
Johnstown, CO 80534-9156
Phone: (970) 587-7077
SLast edited by RedZMonte; 07-08-2010, 03:16 PM.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
