Gasket matching Upper intake runners
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    #31
    Here's 93s pics. I was asked to post them. On the right track.. with a little refinement... Not bad. Now needs polishing.
    • 93vinx
      • Dec 2003
      • 154
      #32
      not done yet, yes much polishing , they arn't as rough as the seeem, the way the bits cuts give them a different loo from different angles and give different feels has any one tried groves to swirl air?
      vrrrooooooooooooooooom i need new exhaust
      • Lyle's GTP
        • Jan 2004
        • 1345
        #33
        You should get your hands on a few 120 Grit flap wheels. They will smooth that out like butter.
        Lyle
        • 93vinx
          • Dec 2003
          • 154
          #34
          pic
          the tb, heh i found out how to post pics lol i turned down the pixels for yu 56 k'ers
          • 93vinx
            • Dec 2003
            • 154
            #35
            i have flap wheels but i cant get in deep enough, i think i have devis4ed a way though i have a dremle also that i use on finer work
            • Lyle's GTP
              • Jan 2004
              • 1345
              #36
              I think you can get 1/4" extensions. They have a set screw that holds the burr.
              Lyle
              • 93vinx
                • Dec 2003
                • 154
                #37
                i have a 3/8, 1/4 are hard to find if they make them because i haven't senn them, if i use the 3/8 it spins out of round..gay
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  #38
                  Lyle
                  Yeppers! And visit the site I posted earlier. Has a lot of good info. I have ported and polished more V-8s than I have kids! Don't ask...............
                  • dykz34
                    • Jan 2004
                    • 793
                    #39
                    I did mine w/ a die grinder. No extensions though because you can't go too deep.
                    • grandprix34
                      • 168
                      #40
                      I didn't go in deeper into the port because I believe I read it or someone on the board mentionted that you should only go deeper if there are obvious gasting flaws such as bumbs or any other obstruction. Don't know about that though.
                      This was my first time porting the runners, the next time is gonna be the lower intake.
                      FOr now, I have already started on the heads .
                      \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
                      - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
                      - 160* T/stat - Dual 40 Series Flowmasters
                      - Hi-Flo Cat
                      15.2@95mph - GTECH P/B
                      http://home.rgv.rr.com/tjperformance/Cap0005.mpg
                      • 93vinx
                        • Dec 2003
                        • 154
                        #41
                        i went past the plat cause i blocked the egr porting, also smpotthed most of the bumps, looks good dyk
                        • dykz34
                          • Jan 2004
                          • 793
                          #42
                          You went past the plate? Mine was smooth as silk behind it... I don't understand what you did. Unless you went WAY into the plenum?
                          • 93vinx
                            • Dec 2003
                            • 154
                            #43
                            i went about 3-5 inches past and took out any flaws, also there is a openeing where the egr gas's would normally come from, i blocked it and its smooth now
                            • 4spdz34
                              • 185
                              #44
                              george u are crazy. not hatin or anythign but u might have a vacuum leak with that porting work.
                              • 93vinx
                                • Dec 2003
                                • 154
                                #45
                                lol i guess we will seee
