Should I turbocharge, twin-turbocharge, or supercharge my '95 cutlass supreme sl? It has a LQ1 in it.
Turbo Or Supercharger
check out the boost section if your serious. TT doesnt really make sense in your application. turbo is the most feasible option if your gong to do it.
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Plus, turbo lag is nice for establishing traction before the power comes on, where as with a roots style s/c, you have power now and have to take it easy off the line to hold traction. Then it falls on it's face at high rpms since it's out of its efficiency range.-60v6's 2nd Jon M.
exact story of the L67/4T65E... except you forgot transmission breakage due to boost instantlyOriginally posted by pocket-rocket View PostPlus, turbo lag is nice for establishing traction before the power comes on, where as with a roots style s/c, you have power now and have to take it easy off the line to hold traction. Then it falls on it's face at high rpms since it's out of its efficiency range.
In a perfect world there is no transmission breakage...Originally posted by robertisaar View Postexact story of the L67/4T65E... except you forgot transmission breakage due to boost instantly
Or L67s...-60v6's 2nd Jon M.
I would also have to say turbo, unless you find a local shop that's willing to do a centrifugal supercharger (like Vortech, Paxton, etc). A roots type supercharger will stick through the hood if you try to put it between the cylinder heads. Of all of the options, turbos generally make the most power and torque, but centrifugal superchargers are the easiest to tune and easiest on the engine.
325 whp 350 lb-ft
My turbo "piping Kit" will be up for sale sometime in the near future. Im building tubular manifolds and replacing what i have. It would be alot easier then having them built from scratch... It does have a T4 flange on it so you would need to run a larger turbo or change the flange. If your interested PM me.
SShane "RedZMonte"
Wow, that would be nice... save me alot of time and effort... turbo just may be the next step after/if I ever get that getrag 284 in.Originally posted by RedZMonte View PostMy turbo "piping Kit" will be up for sale sometime in the near future. Im building tubular manifolds and replacing what i have. It would be alot easier then having them built from scratch... It does have a T4 flange on it so you would need to run a larger turbo or change the flange. If your interested PM me.
S
P.S. still lookin for pedals and parts...
DG
Shane,
You making it with a divided T4 flange and 3" downpipe? That would be really nice...
325 whp 350 lb-ft
I am makin it with a divided T4 and eventually a mandrel dp... 2.5" most likely...Shane "RedZMonte"
single turbo is all youll need. dont be like this guy his mom obviously forgot to take him off the bottle while he was a toddler. as for transmission breakage zzperformance has a whole line-up of 4t65e upgrade parts. i.e. 4340 chromoly input, output and 4th clutch shafts. also if your blowing your 4t60/4t65 while goin into boost then take it out of overdrive b4 you race if your modded you should be in manual 3rd or (regular drive for the 4t60) anyways while your driving till you get to 55mph or higher or you take more risk of blowing your 4th clutch shaft.Originally posted by 86FieroSEv6 View PostNeither, big squeeze all motor FTW!
