poly engine mounts
  • Jake91
    • Dec 2008
    • 202
    poly engine mounts
    does anyone make poly motor mounts for the dohc w-body
  • Smittro
    • Aug 2009
    • 94
    I don't know if anyone makes them for the LQ1, but from my experiance with polies on f-bodies they are much harder than stock.. You will likely be giving up a little comfort will them as well.. The harder the mount/bushing the more vibration and sometimes noise that will be transfered to the inside of the vehicle also.. Many times polies will squeak and or make chattering sounds over bumps and so forth..
    As with anything tho it's always up to the owner and what you like/want..
    • timg
      • Feb 2004
      • 718
      Fast FWD performance made some. There have been a few guys who did their own DIY solutions. ZZP and Intense also had them for certain applications.
      Tim
      325 whp 350 lb-ft
