crank sensor
  • Bigdwg03
    • Jul 2011
    • 10
    crank sensor
    i have two LQ1 blocks i bought both new in the crate and both were supposed to be 95s my question is why does one have the crank sensor in the pan and the other is in the block???? the one with the sensor in the pan is my back up should i grenade the one in the car is it going to make a difference in tuning when i use the other block with the sensor in a different location???
    thanks
  • Bigdwg03
    • Jul 2011
    • 10
    also if i used the forged 3500 crank do i HAVE to use an external crank trigger or can i use the internal reluctor ring on the 3500 crank???
    thanks
    • Dave96z34
      • Apr 2005
      • 624
      yes
      • Schurkey
        • Apr 2007
        • 339
        What are the part numbers for the assemblies? Same number, or different?
        • phonedawgz
          • Aug 2010
          • 11
          The sensor in the pan is an oil level indicator
