WTF kind of intake is that?! Someone find out! *PLENUM*
No, the 3.4 DOHC in Lumina Z34s is different than that in a Fiero.
What?
LMAO Aaron what the hell are you talkin bout.. I hope your joking. I too am curious what gains i would see by putting that on my gtp if see any at all considering im not turbo...
It would fit in a Z34, most likely. Unless the way it is angled, it might hit the hood some. The only gains would be after about 6k rpms (guessing here), or in that area. That is like Mike Smith (right name?) that put the shoebox sized plenum on his lower intake. He netted something like 280 to the tires, but it only had a very short power band. He ended up loosing alot of low end, but gained like a mofo up high, very high.
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
It would fit and I was joking becuz that was a very stupid question
It went from 177 to the wheels to 240, so quite a gain. With this intkae, the car pulled and made power all the way to 8,000rpm, with stock cams, heads, valves, etc. Aftermarket springs of course.
yes that is my Fiero in the above pic.. That was a shot shortly after the GT returned from getting the swap done. It still needs to be tuned and the aluminum polished more and detailed out.
Nice car! What engine management are you using? Stock, aftermarket? What size turbo is that? What psi are you running? Is that the motor that there are pictures of the build-up on the WCF website?
