Oil Pressure at the lash adjusters?
  • Q
    • Jul 2004
    • 46
    What is the factory oil pressure in the valve lash adjuster galleries? Is it simply the regulated oil pressure from the pump? Or is it regulated down even further?
    Thanks in Advance,
    Q
  • Juglenaut
    • Dec 2003
    • 1130
    It is bypassed to run at a set volume and pressure by way of a bypass valve. At least I think it is.
    what is your idle pressure, at 2k, at 3k and so on.
    I am back
    Mechanical/Service Technican
    • Q
      • Jul 2004
      • 46
      I need the info for a non-stock application. I'm looking for the volume and pressure numbers so that I can set up a regulator to oil the lifetrs/lash adjusters externally.
      Q
      • butchville
        • Jul 2004
        • 41
        wouldn't it be same as engine oil pressure is in hydralic lifters you need the volumne to conpensate for the larger area around the adjusters wouldn't this make sense since lifters are half the size with about the same clearence
        • Q
          • Jul 2004
          • 46
          A number of OHC and DOHC applications are pressure-limited to prevent lifter pump and susequent cam damage. They are different than hydraulic lifters in pushrod applicaitons. The volume (flow rate) is not as critical as the pressure.
          I suppose I can try to get a gauge onto a running engine of no one can come up with the data.
          Q
