96 accelerator cables
  • 93vinx
    • 154
    i am doing the 96 intake swap, is the thorrotle linkage the same?, i have no brackets how is the the 96 set up has anyone had this problem? my tb has the pulley on it but i have nothing to secure the lines.
    vrrrooooooooooooooooom i need new exhaust
  • Anonymous
    The lines should be the same, just routed differently do to where the TB is. So you may have to move them around, but they should still slide in just like normal.
    • 93vinx
      • 154
      no bracket?
      • dykz34
        • Jan 2004
        • 793
        The lines are different (you can modify them to work though) and you will need the bracket to hold them.
        Don't listen to Aaron.
        • Anonymous
          The lines should be the same. A metal wire liek thing with a small canister, like a small beer can , at the end that wraps around to grab the pulley. Of course the bracket will be different, but the lines should be the same just routed differently. Most all cars use this type of throttle cable...
          • 93vinx
            • 154
            lol
            thanks i didn't kno what one looked like can you explian the little thing again i don't under stand what a cylender is lmao, i was wondering about the bracket, i didn't get one, 'i'm in the middle of the swap rite now. i wish i could have gotten everything off my slef but instead i hadda order it form tennesee
            i got it for 110 $ but i hadda go buy intake bolts , make a cable and get the thermostat housingits goin well i making a spicket on the new 96 valve cover( doesn't have ne thing) for my pcv, i kno it should be ok but i want onejust in case.
            • dykz34
              • Jan 2004
              • 793
              Aaron, the cruise control line is different on the 96 style. The throttle cable uses the same line, but the cruise control has to be modified. Also, the bracket that holds the throttle cables is too far from the pulley--therefore, the throttle plate does not close all the way when the cable is "limp".
              • Anonymous
                Ok, I was just going off of what I have seen, I havn't actually taken the two and compared them.
                It's gonna suck getting mine to work. I have to turn 2 different pulleys at the exact same time, and I dont know how I'm gonna set that up.
                • dohcfiend
                  King Chalupa
                  • Jan 2004
                  • 2351
                  hmmm. i will be running into this soon enough thanx for the heads up.
                  • 93vinx
                    • 154
                    big problems, dyk you said the cables are the same? cuz i pan on gettting the 96 bracket, i had to make my own and have barely any room, its woorking though and the car is running. low end loss is noticable but pulls alot harder at the higer r's. the plenum actually touches the rubber on my firewall. pain in trhe ass swap, not sure if its worth it yet, gotta do some testing, but my hard star problem is gone.
