cam hold down tool dimensions??
  • 95grandprixgtp
    • 5
    Can someone tell me where i can get the dimensions for cam hold down tool. stock size, hole size, bolt size, hole location, etc... If at all possible, when doing my torque converter this weekend, i wanna also do my cam timing. I have a friend who is in machining at the local vo-tech, and will get him too make me a few of them before the week is over if i can get the info quick enough.
    THanks, Kevin
  • 95grandprixgtp
    • 5
    Just figured i'd make an a$$ outa myself, and answer my own question after doing a little more research.
    http://www.60degreev6.com/index.php?p=pages&pid=3
    • grandprix34
      • 168
      \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
      - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
      - 160* T/stat - Dual 40 Series Flowmasters
      - Hi-Flo Cat
      15.2@95mph - GTECH P/B
      http://home.rgv.rr.com/tjperformance/Cap0005.mpg
      • 93GTP
        • 125
        I recommend the use of 3/4" steel stock versus 1/2", it fits better into the carriers and it's a hell of a lot strong, my 1/2" hold downs coultnt even handle 20 ft/lb's without deformation.
        Here's a comparison between them:
        [img]ftp://142.163.99.88/newpics/105-0528_IMG-2.JPG[/img]
        And here's the reason why I made a set of 3/4" hold downs:
        [img]ftp://142.163.99.88/newpics/105-0530_IMG-2.JPG[/img]
        • Anonymous
          Did you use 1/2" hollow (or whatever its called) or solid steel bar?
          • 93GTP
            • 125
            Hollow? What?
            For the 1/2" hold downs im not sure on the exact material, got a buddy to get me some of it. It wasnt that strong, but it wasn't "hollow".
            For the 3/4" tools I just grabbed some 3/4" steel billet stock from the machine shop at school, they are very very strong.
            Another pic for the hell of it:
            [img]ftp://142.163.99.88/newpics/105-0535_IMG-2.JPG[/img]
            • Anonymous
              Ok, thats what I was wondering. Thanks. The cam hold downs I have here look kinda bent too.... Ill have to get some 3/4" for when I do my belt.
              • jmgtp
                • 1219
                damn mine are 1/2" and I couldnt bend them if I tried. Actually the handle that I have on my pulley holder is the same 1/2" keystock and I could put as much force on it as I like without it deflecting. Sure that you were using steel? Either way if 3/4" fits in the carrier I guess you cant go wrong.
                1994 Corvette
                LT1/ZF6
                2006 Dodge Dakota 4x4
                3.7/42RLE
