do I need a cat?
  • wireman121
    • 29
    do I need a cat?
    I currently have a custom magnaflow exhaust. It has a high flow cat, a resonator, and 2 mufflers, with all new piping. I recently started hearing a rattle under my car - and I checked it out today. The cat is bad. I am wondering, do I need to have a cat? If I remove it, will that improve my performance, or hurt it? I can't remember if it is this or the 4.3L S-10 engine that runs worse when you pull the cat. Before I do anything I want to make sure I am gonna improve, not hurt.
    Thanks
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    thats trial and error. pretty much your just removing backpressure so it should be a good thing, i cant understand why it would hurt. i guess as long as you dont have an o2 sensor after the cat, you should be fine, that way the ecm's not getting a wrong signal.
    • your_I.D.
      • Mar 2005
      • 337
      Do you have emission test for vehicals were you live? If you gut the cat you may fail the test. Just a thought you may want to consider.
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      • wireman121
        • 29
        I'm not concerned about the emissions testing. I just want to make sure I am not going to have a power loss if i gut it.
