belt size with FFP under-drive pulley?
  • fieromadman
    3.4 DOHC fiend.
    • Feb 2004
    • 130
    Hello,
    I ordered the FFP pulley and was wondering what size belt i will be needing with the pulley, or if the idler will accomadte for the difference? Thanks!
    Jeff
    3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
    1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
  • RebelGT
    • 642
    RE: belt size with FFP under-drive pulley?
    it will have the belt size info in the instructions
    26+6=1
    • 5speedz34
      • 301
      Usually, it's 1" shorter than stock.
      • 3car
        • Apr 2005
        • 8
        Approx. 1" shorter is correct. I just had this installed and
        it works great. Only issue I have is it seems to be a bit
        noisier under the hood( timing belt area). Anybody else
        every get this, or do I have something that needs to be
        looked at.
        Thanks, Brian
        92 Z-34 FFP GOODIES, STAINLESS MAGNAFLOWS
        • 5speedz34
          • 301
          When I used to have my car sometimes, it would be a little noiser and I could hear at WOT in the car, but nothing to serious.
