Originally posted by firechiken
the heck with cams how about lifters
Its in production now. http://www.bmwworld.com/engines/valvetronic.htm1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
The lifters will come apart if you bang them plunger side down against a piece of wood. You want the lifter to hit wood as square as possible. May take a few times pretty hard. (thats how I took one apart. is there another way?)Originally posted by butchvilleif you can bleed lift down you can pump it up. your right though lift on cams the same as before. controled lifter pump up it can work just ain't had time to work it out anybody know how our lifters ar put together.
UPDATE!!!!!!!!
YES THERE is a better way. Take a 13/16 deep socket. Put lifter on it wither plunger pointed into socket. Than bang socket on concrete a few times. Plunger will fall into socket. No chance of damaging lifter this way.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
update edited in above1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Talked with Rhodes Lifter today. They said they could modify our original lifters to act like rhodes. For $125.00 + shipping for a set.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Money better spent towards reground cams.'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
I was thnking both with a pretty radical cam grind i cam up with.
around:
4.00 lift
290 duration1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
I belive that was Mercedes, and they did use solenoids and no cam, but if I remember right, the chassis electrical had to change to a 50+ volt system to operate right.Originally posted by firechikenNo, that's not it. What I'm talking about has no cams at all.-60v6's 2nd Jon M.
Ah, neither one of us were thinking out our butts!
And why are they doing this? Good question... one guy answers it like this:
This found part way down on:Think about the tradeoffs a cam has to make on engine performance, Ohl said. A racing cam, in one example, is shaped to optimize engine output at high speeds without regard for the way it roughens up an idle. With camless valvetrains, "We don't have to live with that compromise," he said.
Are you in referance to ruffing up the idle? If so thats the whole point of rhodes type lifters. The help smooth idle and raise vacuum at an idle.Originally posted by pocket-rocketAh, neither one of us were thinking out our butts!
http://www.memagazine.org/backissues...ontrolled.html1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
