Lowering and Handling
  • Jculler1610
    • Jan 2005
    • 36
    Hey, I have a 93 z34 my name is joel for those who dont know. I kow that ffp makes a coil over kit for the back to replace the mono leaf but is there a way to get beter springs that also lower the car with out going this way. I like the mono leaf it seems to handle well and also to put the coil overs in it cost like 600 or somewhere up there. tell me if i am wrong but you can use monte front springs but is there another way or spring for the rear.
    Thanks
  • Jculler1610
    • Jan 2005
    • 36
    also lol, I want to possible make or buy a rear sway bar. are there any designs out there and what would be the best materials to use.
    Thanks again
    Joel
    • Doubt_Incarnate
      I still watch ROBOTECH!
      • Jan 2005
      • 1130
      your gonna have to search around to figure out how to lower with a mono leaf. as far as a sway bar, unless you have a machine to bend a spring steel rod on then you'd be better off grabbing a torsion bar from another vehical, and fabbing up some mounts, and some arms, similar to stuff you see in the jegs catalogs.
        • 9191
        I already moved your original post to the SUSPENSION area where it belongs. So look there for replies.
