lq1/284 shift points????
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    what are the best shift rpm's for each gear to yield the best results in a drag race?
    on the auto's it was like 6-6350 i believe. i would imagine to get better results from the manual, i would have to lower these numbers since the gears are closer together.
    maybe 5700 to 6K? (depending on the fdr difference)
  • Juglenaut
    • 1130
    RE: lq1/284 shift points????
    Top of the power band of coarse, with a manual it is easier to achieve and stay within the top part of the power band.
    5750 I used as a shift point.
    I am back
    Mechanical/Service Technican
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      kewl thanx. also, what would you consider the best launch rpm?
      • Juglenaut
        • 1130
        3800-4000 minimal tire slip. A good 284 will almost glide itself into gear without ripping the tires loose at that rpm, and at a point where the 284 locks floor it, shift before 5800. float the gas pedal about half and quickly shift as fast as you can a release then floor it shift before 5800.
        Ah man I miss my GTP sigh******
        I am back
