Weight Reduction
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 506
    PLEASE DO NOT YELL ON THE INTERNET USE YOUR INDOOR VOICE
    Fiberglass body panels. All extraneous components from the cabin, like carpet and seats. Take 'em all out except yours.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      change your exhaust around and you get both hp and loose weight. i went to a high flow exhaust by doing the following:
      gut the convertor, replace resonator with high flow muffler, and remove the 2 can mufflers altogether.
      with the removal of the can mufflers and shielding above them i lost 40+pounds. exhaust is brutal loud(i like it ) i may have to switch to a different muffler if i get a ticket or 2.
      switching to a 5 spd is another hot ticket. it is lighter and the gearing makes the wbodies alot more fun to drive. not only that but then u can get an aluminum flywheel and better clutches too.
      • OldSkoolGP
        That guy over there
        • 930
        I have discovered too a lot depends on the W-body you have too. for some unknown, the Z34 actually 190 pounds more than the GP coupe outfitted with the 3.4 and 5-speed. I was reading a review on W-body from 1992 about the best sport cars for your buck. They tested a Z34 and a GP SE, both with 3.4/5-speed. The GP weighed in at like 3240 pounds, while the Z34 weighed in at 3430! Funny thing is, the Z34 was 3 tenths faster in their testing.
        • z34phoenix
          • Jun 2005
          • 469
          • z34phoenix
            • Jun 2005
            • 469
            just found this ... it is for a 3800 but might work for our dohc or what ever engine you got. it is a pulley replacement for the AC. although for the $300 price tag, i would just buy a new shorter belt and bypass that area. cause on my DOHC if i shorten the belt it would be fine without the AC
            • Mach10
              • Jan 2006
              • 232
              #21
              Jesus... I bought a pulley-delete from Fieromadman for $40.... All it needs is a $25 idler replacement from Autozone(or equivalent)
              http://60degreev6.com/discussion/viewtopic.php?t=8534
              • wiseway
                • Feb 2006
                • 28
                #22
                P/S Eliminator
                Do you sell a power Steering Delete Pulley. If so what is the price. thank you.
