My 97 3.4 DOHC has wornout exhaust valve guides and one guide has actually slide down about 1/8. Cause valve guide seal to float freely. I have a spare set of heads to build. Wanting some info on porting the heads. As far as reshaping them. Kevwood any info?
NEED input from cylinderhead guru's
1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Tags: None
well im pretty much as lost as you are except im flying by the seat of my pants. Right now im in progress of porting some earlier heads, you can check it out here: http://www.fiero.nl/forum/Forum2/HTML/068893.html
so far the results look pretty encouraging.3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
fieromadman you might want to check this out. http://60degreev6.com/modules.php?se...view_album.php gives a cutaway view of the ports.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
thanks man, I had forgot all about that page, good luck finding out what you would like to know, im trying to find it too, i'll let you know what i come up with LOL.3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
