Hood Vents
  • Scott205
    • Jun 2005
    • 265
    Hood Vents
    I have been thinking about this for awhile. Right along the thought of using a CAI (Cold Air Intake), that everything at a cooler tempature (well trying to get it reasonable anyway) should produce more power.
    I know the older Lumina Z34s had hood vents (I assume they actually were working) and as the car rolls down the road the cooler outside air blows under the car, and the hottest (heat rises) air under the hood is blown up and out through the hoods. Didn't they make a few Pontiac GPs this way too?
    Anyone actually measure and see if it makes a difference? I have an Olds Cutlass.. just wondering on our side.
    2014 Chevy Cruise LT
    2000 Kawasaki ZX-6R Ninja Motorcycle
  • Lyle's GTP
    • Jan 2004
    • 1345
    Yes, the 91-96 GTP's had the louvers. But they were blocked off, really only for show. But you could easily remove the covers and make them functional.
    Lyle
    • mfewtrail
      ~600hp worth of 3.1's
      • 170
      Lyle
      They're not blocked off, they just have drip pans on them in order to keep water off of everything under the hood when it rains(go put your hands over one of the louvers after you've driven somewhere...heat definitely pours out of them). The hood louvers are placed in a low pressure area on the hood so that they actually draw air out from under the hood when you are up to speed(air flows over the louvers and "extracts" the air from underneath the hood...that's why they're commonly referred to as "heat extractors").
      Matt F.
      TGP 1/4 mile times
      http://photobucket.com/albums/y33/mfewtrail/
      1990 TGP Coupe VIN Database
      • OldSkoolGP
        That guy over there
        • 930
        If you want to know if yours work, spill a little coolant on your crossover pipe and run the engine for 10 minutes. Turn it off and loook at your hood. I bet you see steam coming out of the louver!
        • Scott205
          • Jun 2005
          • 265
          So do you think lowering the under hood temperature is a good thing? Why not the Olds? or the basic Luminas?
          I remember the old 50's and 60's cars had "portholes" to help do the same thing
          Heat build-up under the hood has got to cause other issues, not to mention your radiator doesn't cool as well, your engine run hotter, the electrical cables deteriorate faster..
          • donk_316
            • Mar 2004
            • 427
            not to mention 50s and 60s cars ran shitty carbs that would percolate under heat.
            1984 Indy Fiero 3.4L
            13.7 sec @ 98 mph
            *ALL THROTTLE AND NO BOTTLE*
            • TurboGt
              • Oct 2005
              • 154
              Also you want to pull the heat out from under the hood not push cold air in. You will get more air exchanged this way and you wont be forcing the air under your car.
              Mega Squirted Fiero
              How I did it here
              • HisCar
                • Jan 2006
                • 12
                Well obviously the lumina z34 and gtp's catered to a diffrent kind of consumer than the cutlass or even the base models of those cars. Therefore marketing prolly liked the idea and thought it looked kinda sporty. Kudos to them for even caring enough to make them functional. I can see the cutlas looking goofy with them though. But they would have been a good idea on all 3.4 equipped cars. These motors just seem to put off more heat than their bretheren.
                • DEI37
                  • Jan 2004
                  • 516
                  Hey, if someone comes up with something for a Cutlass, lemme know. I want to do something, and the stock hood might could even be a guinea pig, as the leading edge is all rusted, and needs to be replaced. I'm working on heated washer nozzles for hood placement right now, but if someone comes up with hood vents, I know I'd like to do something like that. It's hot under there.
                  • mfewtrail
                    • 170
                    Here's a Cutty(white convertible) with heat extractors from the late model Daytona edition Grand Prix's(also found on "Special Edition" Grand Prix's around the 2000-2001 model year).
                    Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                    I can look up the part #'s for those louvers & attaching hardware if you're interested(I've posted them for someone else on another board in the past).
                    Matt F.
                    TGP 1/4 mile times
                    • DEI37
                      • Jan 2004
                      • 516
                      And those are functional as well, 'eh? That looks pretty decent, in my opinion. Are they GM part numbers? I'll poke around for 'em, but if you can come up with them, even if just to verify my findings, that would be appreciated. Thanks.
                      • RednBlack
                        Wood Hippie
                        • Mar 2004
                        • 2795
                        That 94 Ragtop is badass!
                        • GTP_MuNkY
                          • Jan 2006
                          • 113
                          I have a 95 GTP with the hood louvers...anyone think it would make any difference at all removing the drip pans from under the louvers? maybe allowing the air to move out more freely?
                          Thanx
                          1995 Pontiac Grand Prix GTP
                          3.4L DOHC
                          My Cardomain Page UPDATED MARCH 10, 2006
                          • mfewtrail
                            • 170
                            Pretty sure they're open underneath(with drip pans for ran underneath)...I'll dig up some underhood shots from a late model GP with them if I can.
                            -Extractor 88894520
                            -Extractor 88894521
                            -Deflector (Rain Gutter) 88894522"
                            Those are the part #'s from the Daytona hood louvers. According to gmpartsdirect the louvers are $162/each through them....you might want to start searching junkyards and hope you come up with a Daytona 'Prix there.
                            Matt F.
                            TGP 1/4 mile times
                            • Juglenaut
                              • 1130
                              mfewtrail is correct on this.
                              as air is moving over the hood it creats a low pressure on the louvers pulling the air out that why they appear backwards (gtp) this increases the effect. Like putting a straw in a cup of fluid and blowing across the top pulls fluid from the bottom of the straw to the top. Z's are to the side.
                              I am back
                              Mechanical/Service Technican
