Dohc mods for 2k6
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    Dohc mods for 2k6
    it is that time again. what are some of you dohc-er's are planning on? although i know what most of you are up to already
    1. finish engine build: en quene
    2. port heads: en quene
    3. stage 3 clutch: got it
    4. stage 3 pressure plate
    5. aluminum flywheel
    6. poly engine mounts: starting on but nothing too conclusive yet.
    7. coil overs
    those are my mandatory things for this year.
    things id like to see are:
    1.headers(milzy motorsports)
    2.lsd if it gets done this year
    3. finally get that turbo piping ready for sale.(no plans on turbo for myself btw)
    4. find some aluminum cam gears and some1 willing to guarentee they will work correctly.
    5. also if i run into some cash a cam regrind....duh.
    although this looks like a nice plan. things hardly ever go as planned. if i get a deal on something, i usually will automatically bump it up to the top of the list and something will then get bumped off for next year.
  • ez112
    • 258
    Probably by the end of the half (end of June) I'll probably have these:
    1. Milzy Motorsports Ported Upper and Lower intakes (lower being done right now)
    2. Timing modification (right now)
    3. Northstar throttle body with custom intake arm (plans being made)
    4. 3000 stall torque convertor (buy in process)
    5. Custom electric water pump (still in the works)
    Hopefully My transmission won't start acting up after all that. Right now I'm amazed it's still kicking ass. Maybe July on then, the following will be on the list.
    1. Cam regrind
    2. 4T60E-HD rebuild with a limited slip
    3. Possible Centrifugal Supercharger incorperation
    Rest assured I'm always down for making this engine really stand out.
    1999 SVT Lightning
    1996 Monte Z34 R.I.P.
    Next BEATER: a C5
    http://www.fquick.com/ez112
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      Curb feelers and a beer cozy.
      Oops, I can't drink and drive anymore.
      Here is a thought...Wireless Tuning! Hmmm........
      • Fierobsessed
        • Mar 2004
        • 219
        1. Buy house
        2. Finish moving.
        Once that is done, then I think I will tackle my Quad4 and turbo it.
        But for the 3.4 DOHC... I have a lot I havn't done, but plan too sometime this year, into the next 2 years. I'm slowly collecting parts in the meantime. But with the future purchase of a house, comes a lack of time, and cash.
        But the to do list is still there.
        1. Purchase 3500 crank and modify for 7X reluctor
        2. Purchase 4.3 rods, and modify for 3500 crank
        3. Line bore the block for the 3100 mains
        4. Order custom pistons/rings
        5. Notch block as needed, modify block for cast pan.
        6. Finish Supercharger manifold
        7. Make intake pluming
        8. Make custom headers
        9. Make custom exhaust
        10. Wiring
        11. Modify car to accept 3.4 DOHC
        12. Purchase Clutch and transmission (6 speed G6)
        13. Mount and configure transmission and engine to cradle
        14. Tune 3.4 DOHC with N/A manifold
        15. Install blower manifold and further tune.
        Sounds like a lot, but there is so much more to it. The more I think about it, the more it hurts. Especially when I plop down my life savings for a home with a garage to work on the engine inside of. For now, I just have an impressive collection of parts.
        • z34phoenix
          • Jun 2005
          • 469
          Well for me... I have to catch up on a lot of fixes but here it goes....
          1) Alt, tie rod ends, alignment, UD pulley
          2) DHP
          3) O2 sensor, Oil Oring seal, intake gaskets AGAIN!, valve cover gaskets
          4) Poly swaybar bushings, kyb sturts, misc interior fix's steering wheel control wires & ac Blower controler
          5) Sterio HU, OBD 2 scaner
          • Fiero Brick
            • Feb 2006
            • 71
            If money starts panning out better, I'll be wrapping a Fiero around the good ole' LQ1.
            87 Fiero GT
            2.8 liter v6
            • Mach10
              • Jan 2006
              • 232
              Much enjoyment to be had with an LQ1 wearing a skin-tight Fiero.
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                i to plan on using a fiero body eventually, but i would like to get a wbody down to the 14 second bracket(if not low 14 second bracket) be4 i go to a fiero and have a truly sick lq1 fiero.
                unfortunately, it will not happen this year as i am only devoting 1/2 a year to the lq1 this year b/c i am neglecting my fbody too much.
                ok peeps 1/4 of the year is gone...updates????? or new peeps????
                my update goes as follows
                1. finish engine build: shortblock finished
                4. stage 3 pressure plate: waiting for it to show
                5. aluminum flywheel: got it
                6. poly engine mounts: dead
                7. coil overs: en quene
                ok, i have an empty spot on my main list now. of these things listed what would u guys think i should shoot for?
                or if u have an alternate suggestion, i'd be happy to hear it.
                • timg
                  • Feb 2004
                  • 718
                  Learn to weld and buy a TIG welder. Buy a metal cutting bandsaw. Move to a house with a real garage floor and 220V outlets. Swap in the 97 Z34 engine and wiring harness I have. Swap in the 97 4T65E-HD I have. Swap in the steering rack from a TGP. Replace all the bushings I can with poly parts. Rebuild my turbo kit from the ground up with 2.5" intercooler piping, 3" downpipe, and custom, tubular manifolds. Probably sell all of the turbo kit I have now (turbo, wg, bov, crossover, downpipe, and intercooler plumbing) and replace it with a GT35R or GT40R and Tial WG and BOV's. Retune for 14 psi with the PowerTuner. Enjoy the power. Note, this may take well over a year to fully complete everything.
                  Tim
                  325 whp 350 lb-ft
                  • tijuana_no
                    • Aug 2005
                    • 261
                    i feel sad every time i see my cutlass supreme conv. park in the garage.
                    i need to rebuilt the engine.
                    1.port the heads
                    2.port the upper and lower intake(don't know where yet ,if any suggestions )
                    3.port the thorrtle body (also help here)
                    4.computer ship.from ben,i would like to get as much parts or service from him,but don't know the parts he can help me with.
                    5.dog bone mount
                    after all that is done ,and i am comping again in sq. in usaic ,i plan to upgraid to a turbo,but i need help .first a good mech in houston.
                    i just love to watch the wheels turn around and around
                    • Husky
                      It's like... ya know?
                      • Aug 2005
                      • 200
                      Okay, I'll be starting from scratch on a motor that's sitting on a stand in my garage.
                      1: T03 baby!
                      2: FFP Underdrive Pulley(Got it, have to install on new motor)
                      3: NOS Nitrous Wet Kit
                      4: Getrag or MT2 Swap
                      5: Buy a Geo Metro to drive while the GP is layed up.
                      1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
                      1995 BMW 540i, Alpineweiss-III, 6-Speed
                      1995 BMW 540i, Schwarz-II, Automatic
                      2004 Honda 919, Light Silver Metallic, 6-Speed
                      • dohcfiend
                        King Chalupa
                        • Jan 2004
                        • 2351
                        Update is as follows
                        4. stage 3 pressure plate: got it
                        6. poly engine mounts: dead for now
                        7. coil overs: got it and installed it
                        2.lsd(if i can part with my tranny to get it done)
                        my want list is getting smaller and more realistic now and my must do's are nearly completed except for the heads and final engine assembly/installation(slack ass machinist )
                        so i'll put it to u guys again. on the want list, which one of the 2 would u personally pick and why the 1 over the other?
                        • Fierobsessed
                          • Mar 2004
                          • 219
                          I put in an offer on a house today, looks like its going to be mine... Hey, its #1 on my list of things to do to get the LQ1 project moving. I'm going to be one broke bastard next month.
                          • tijuana_no
                            • Aug 2005
                            • 261
                            fieroblessed, i know how you feel , i also just bought a second house and is eatting up all my cash.haven't done nothing to my cuttlass ,exept i felt bad last week and dynamat my trunk.
                            • z34phoenix
                              • Jun 2005
                              • 469
                              2) DHP
                              times change and so do plans:
                              -alt, tie rods, alignment, ud pulley *installed*
                              -bushings, ac blower *complete*
                              -Wing *installed*
                              -DHP Power Tuner *in Mail*
                              Next: either
                              -O2, Oring, Gaskets + plugs, wires
                              -Turnsignal, steeringwheel controls
                              -High Flow Cat
                              -New Rubber yoko 100's
