I love the LQ1!
  • Husky
    It's like... ya know?
    • Aug 2005
    • 200
    I love the LQ1!
    So, I was using a six point socket to remove the bolts holding the cam cogs on... And it rounded them off. Yay!
    1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
    1995 BMW 540i, Alpineweiss-III, 6-Speed
    1995 BMW 540i, Schwarz-II, Automatic
    2004 Honda 919, Light Silver Metallic, 6-Speed
  • series8217
    • Dec 2004
    • 387
    The dealer should be able to sell you new ones, I've bought them before.
    Remove the ones that are now stuck by welding on a bolt, nut, or socket.
    What size socket were you using?
    • Husky
      • Aug 2005
      • 200
      15MM Am-Pro 6-point.
      So, more good news. I ran a compression check... The cylinders are ALL LOWER than when I started. What all will cause low compression(They dropped from the 150ish range to 90-120). Could this be because there's a problem with the valves? I lapped each valve pretty good before putting it in. Also, I don't have the crossover or intakes on.
      Oh, and when I crank it, something's leaking from the rear passenger side of the motor. I think it's oil. Fucking piece of shit.
      • series8217
        • Dec 2004
        • 387
        Lapped the valves? Ew.. I recommend getting a real valve job next time.
        Might settle in once you run it for a bit. Why'd you do that if the compression was good before? Did you put new valves in?
        What did you do to this motor?
        • Husky
          • Aug 2005
          • 200
          I messed with it because I don't know when to leave well enough alone.
          I did the headgaskets because I had one cylinder down 40+PSI from the rest.
