Monte Carlo Z34 restoration done.
  • napatiger
    • 490
    It's official, she now runs.......
    5 minute version of 3 year restoration:
    2003 Fender-bender puts my car out of commision for a while.
    Fixed $2500
    2004 I can't get to the O2 sensor so I pull the engine.
    I decide to take apart my first engine, I am a vineyard manager btw.
    Machine shop fucks up my oiling system from misplaced bearing $1800
    2005 Assemble the first time and crack theTrans case $1800
    2006 New kick ass machine shop does a long block for me $2000
    May 13th 2:35 am. Fix last bug and she fires up.
    MODS / NEW PARTS:
    New 4T60E
    105 amp Alt
    48 gram Lifters.
    Magnacor wires 8mm.
    New gaskets and sensors.
    96/97 style injectors
    UD Pully
    FFP motor mount
    SS timing belt cover
    Fender-well intake.
    Hi flow Cat.
    New Motor mounts
    New struts KYB...
    New Eibach springs
    Rear disk conversion, Slotted / Drilled + E-brake
    New tie rod bearings, suspension parts.
    New fuel pump.
    3 Pod Pillar, Oil Pressure, Trans Temp, AF ratio.
    Battery in the trunk with 0 gauge wire.
    Chilton Haynes and GM manuals.
    75 cases of beer, 32 bottles of wine and your occasional bottle of tequila.
    95 MC Z34 Black
  • DEI37
    • Jan 2004
    • 516
    Sounds cool. Get some pics up...and what does it take to do a rear disc conversion? I've got a 1999 Lumina with rear drums that I'd like to change over to discs.
    • napatiger
      • 490
      I would pull the knuckles from a JY, mine came from a 96 CS I think.
      Purchace new calipers and disks, I got drilled/slotted all the way around.
      Puchace new P-brake cable from dealer, rockauto.com will send the wrong one.
      95 MC Z34 Black
