Turbo question
  • 95black34
    • May 2006
    • 19
    Turbo question
    I have a t3/t04e that I was going to use for another project that I never actually got around to doing. I was wondering if this turbo would be a good turbo for my LQ1. It's .60 A/R and .53.
    I am in the midst of pulling my motor all apart and i'm trying to figure out exactly what i'm doing to my motor.
    Also I have another question about the 62mm and 65mm throttle bodies on the 60 degree store says they are for 3100/3400/3500. Will these work on the LQ1 ?
    1995 Black Monte Carlo Z34
    soon to be rebuilt
  • timg
    • Feb 2004
    • 718
    Re: Turbo question
    That's really not enough information to determine the turbo size. Have any wheel sizes or trims? If not, can you measure the wheels? I'm just going to take a guess and say it's too small- most used turbos come from small displacement 4 cylinders.
    The 62 and 65mm TB's will not work for the 3.4 DOHC.
    Tim
    325 whp 350 lb-ft
    • 95black34
      • May 2006
      • 19
      Pictures of it are here. I was going to use this turbo on a 1.8L DOHC Asuna Sunfire but never got around to it.
      I'm pretty sure this turbo would spool pretty bad ass on a 3.4L DOHC because it was a good turbo for my other motor that was even smaller..
      soon to be rebuilt
      • Dave96z34
        • Apr 2005
        • 624
        to small
        • Doubt_Incarnate
          I still watch ROBOTECH!
          • Jan 2005
          • 1130
          youd get boost at lower rpms, might make you feel faster off the line, but once you get over 3K your motor will probly breathe deeper than what the turbo can supply
          • 95black34
            • May 2006
            • 19
            Well thats to damn bad for me then. I'd love to get something for my motor thats going to spool around 2500 - 3000 and pull hard all the way to 6k.
            soon to be rebuilt
            • Doubt_Incarnate
              • Jan 2005
              • 1130
              that would be a huge turbo... N/A the tdc would flow around 300-330cfm @ 6K. a turbo big enough for 15 psi @ 6K would need to be twice that.
              • 95black34
                • May 2006
                • 19
                What size turbos are the guys who are running them here running?
                soon to be rebuilt
                • FieroWannaBe
                  • Mar 2006
                  • 78
                  turbo sizing
                  If you interested in turboing, I Strongly suggest you learn more about them, like how to size them, termonolgies, etc. Please take the time to read these articles, they are worth your time and cand help you undedrstand what your needs really are.
                  Something cool coming soon...
                  96 LQ1!
                  • timg
                    • Feb 2004
                    • 718
                    I'm running a T04E 60 trim compressor with a T4 P trim turbine side (either 0.58 or 0.68 a/r). I really like the GT35R though. The 60-1 is also a good turbo.
                    Tim
                    325 whp 350 lb-ft
                    • RedZMonte
                      • Feb 2004
                      • 1378
                      http://cgi.ebay.com/ebaymotors/T4-60...spagenameZWDVW
                      this turbo would prob. work, compressor is a little on the big side but it should work. pluss you get the gate and everything with it. CHEAP!
                      S
                      Shane "RedZMonte"
                      1992 Lumina Z34-VIRGIN (RIP)
                      1992 L67 Lumina Z34 (SOLD)
                      1990 Turbo Grand Prix (SOLD)
                      • nocutt
                        • 123
                        Originally posted by RedZMonte
                        http://cgi.ebay.com/ebaymotors/T4-60-1-Greddy-Turbo-50mm-Wastegate-50mm-BOV-Valve_W0QQcmdZViewItemQQcategoryZ33742QQitemZ80656 75863QQrdZ1QQsspagenameZWDVW
                        S
                        WWwaaaaayyyyyzzzz tooooo biiiiigggg even for an all out race LQ1...
                        3800 S3 intercooled turbo...
                        • timg
                          • Feb 2004
                          • 718
                          When I spec'd mine out originally, the 60-1 looked awesome. It was even what Turbonetics recommended. The GT35R will have as much or more high end with MUCH more low end though (the most of all of the turbos I listed). The 60-1 will kill the 60 trim T04E at the high end while again giving up a bit on the low end. The 60 trim seems to be a good compromise for a cheap turbo.
                          The 60 trim T04E compressor with a T4 p-trim turbine will give a very solid powerband from 3000-6500 rpm with a 3" exhaust.
                          Tim
                          325 whp 350 lb-ft
