CS130 and CS130D
  • montessgtp
    • 115
    CS130 and CS130D
    Ok These are 2 delco remy Alternators rated at 105 Amps? Does anyone know if this is the alternator that comes in the 3.4 DOHC?
    I cant find parts # on either to match them up.
    CS130 - 105 Amp 84-93
    CS130d- 105 amps 94+
    I wanted a stronger alternator in my 3.4 DOHC, I was lookin at the CS130 but i think they came stock in 3.4 DOHC if anyone knows anything bout this let me know beforei make a 200$ mistake.
    1996 Dodge Ram 5.9/4x4
    1992 Grand Prix GTP LQ1/4t60-E
    1986 Monte Carlo SS 355-3-71SC /200r4
  • BowtieKid79
    • 59
    the CS130 uses an external fan and was used up through 93 on the DOHC. The CS130D was used on 94+ DOHCs. It has an internal fan on it. You cannot swap the two without changing the wiring harness for it. THey both put out the same amps. its just a matter of what year car you have.
    • 4spdz34
      • 185
      the 94+ alt also won't bolt to the prior 93 block
      • montessgtp
        • 115
        Hey this why are alternators suck so bad...
        good lil bit of information....now assuming i have no problem with a alternator
          Wow, that is a pretty good article to read. I have heard of a Mr. Cool kit for our alternators that replaces the rear half of the alt, which is thicker and has cooling fins around the outside, IIRC. Maybe someone here could shed some light on this.
          • montessgtp
            • 115
            I have a iceburg kit on another GM alternator i own...im gonna buy one for the CS130 now..for both my car GP's
              Where do you go to get one of those?
              • GPXSS
                • 588
                Pics of a black texture powder coated iceberg kit:
                I purchased the kit from http://www.alternatorparts.com/ Lots of good info on their site.
                I modify stuff
                  Cool, thanks Chris!
