96 Beretta Project
  • torq455
    If I only had money!!!
    • 1615
    #241
    http://www.tciauto.com/
    or
    http://www.tripleedgeperformance.com/ Dave, This guy knows his sh*t.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • trewyn15
      • Oct 2010
      • 178
      #242
      awesome car and build man!
      2004 Monte Carlo LS
      Build Thread
      Youtube Channel
      ^Add and Sub & I'll Return The Favor^
      • Z26-T
        • Apr 2008
        • 486
        #243
        I recommend TCI or hughes also if they build TQs for 4t60s (which I don't know for sure either way). My powerglide is a TCI, and I'm running a hughes tq in the dragster and camaro. Can't think of any issues i've had with either company.
          Originally posted by torq455 View Post
          This is what I got back from Tripple Edge. 6 days after I contacted him.
          Hi Jonathan,
          Thanks for your interest in using us for a torque converter. I dont have a good suggestion for you off hand as I dont have much experience with your setup other than stock applications or stock and modified 3800 engines which will definately behave different. The problem with most stall rpm ratings is they are only for a stock engine in a given application and there is a world more to the true stall speed. Stock ratings are rarely ever accurate, nor are most aftermarket converters unless tested on a specific application. A 3200 rated converter could stall 2500 in one car and 3500 in the next. For custom built torque converters we use Precision Industries and they will build the converter to match the engine specs and desired stall speed, as well as to match the power adder being used if any. Not all converters are created equal and every combo and power adder will make the converter behave different. A 245mm converter for a fwd application is pretty universal across the board so there really isnt anything model specific. The Precision Industries torque converters use their own proprietary lockup clutch material that is fully compatible with the older on/off style tcc systems and also work fine with newer pwm tcc systems.
          David Norris
          Email: Dave@tripleedgeperformance.com
          Website: www.tripleedgeperformance.com
          I also contacted Precision Industries direct....
          From: jack@converter.com [mailto:jack@converter.com]
          Sent: Friday, October 14, 2011 10:39 AM
          To: jpchmura@att.net
          Subject: RE: Contact Us Form
          The converter we make for your car is a 9.5" Vigilante with a CNC Billet Steel front cover, heavy duty lockup, all furnace brazed and comes with a 5 Year Warranty. The converter sells for $808.04 and the build time is around 5-7 working days.
          800-649-7866
          I can only Image what Tripple Edge will charge me if PI is quoting $808 since they said PI's would custom make one, so I can only imagine when he sends them my info they will come back with the same converter. I really dont need the CNC Billet Steel front cover.
          I'll see what TCI Auto has to say. But right now I'm liking the responce and info RevMax has given me.
          • torq455
            • 1615
            #245
            I have one 4T65E and one 4T65E HD. I forgot that's what Triple Edge mainly works with. Me bad.
            Andy
              They share the same converter though, I can use my 245mm converter on a 65eHD without a problem... The only difference would be what motor I'm working with, and aparently he is used to doing the 3800's and is not used to what power a 3400 can make with my mods.
              • torq455
                • 1615
                #247
                It's a whole different powerband. Therefore, different tranny shift tuning is required.
                Andy
                • Z26-T
                  • Apr 2008
                  • 486
                  #248
                  I'll be at SEMA next week... I could talk to some companies if you wanted to send me a spec sheet.
                    This is what I've been telling converter companies right now.
                    Converter Company,
                    I'm looking to get a new converter for my setup and I'm trying to find the best option. I'm currently running a PDQ converter but I'm not that impressed with it. I've been told its tweaked to around 3195 stall yet when I leave the line I'm at 3800RPM + and on my shifts from 1st to 2nd I'll go from 6500 rpm down to 4818 rpm when I'm not spraying nitrous… When I'm spraying I have an RPM range of 5100-6700 that's it, after 1st gear the lowest RPM is 5100 after the shift is complete. My final drive gear ratios at the wheel are 10.71:1 for first and 5.75:1 for second and 3.69:1 for third. If you ask me the RPM drop doesn't seem like it's enough for a converter that should be stalling around 3200. This is in a 1996 Beretta with a modified motor and 4t60e transmission running on a 100 shot of nitrous. Cam specs are 216/240@.050 duration .517/.568 lift 112LSA this is on a 60 degree V6 engine 3.4L displacement with a 3.5L top end on it. I've currently put down a 12.67@107 last year but the tires were spinning so much I know it can be better.
                    With my gear ratio and tire size assuming zero slip and immediate shift times if I were to shift at 6,400 2nd gear would take over at 3,470. I typically complete my shift around 6700 so I would like to see somewhere in the range of 4200-4500 after the shift… if that's at all possible… I'm honestly not sure. Right now at a 6700 shift I end up at 5100 rpm, and on a second to third at 6600rpm shift I end up at 5200rpm.
                    I was wondering if you could make anything for my application, and what it would cost. My converter is a 10" Diameter, 27 Spline, .824" pilot, 9 1/2" Bolt Circle, it also has a TCC lockup clutch that I would like to keep intact. If you like to start with cores first, a FAFB converter for a 4t60e FWD application is a 2795 stall to start, and it comes with a lockup clutch which I want to have since the car is driven long distances at times.
                    Let me know if there is anything you can do for me and what this would run me.
                    Jonathan Chmura
                    RevMax did ask for an estimate HP chart and I gave them what Ben sent me recently. If you do a MPH/weight to HP calculator you get 317 too... kinda funny... I did my 107 when it was 3125-3150lbs IIRC... my lightest before the brakes was 3040lbs and that was the 13.996@98.06 that I got, that put me at 235.59 hp estimated... I can almost accept that too since I did NOT have ported heads and such then, and also had a very loose timing Chain and the stock lifters.
                    These are 500 RPM increment starting at 2k and ending at 7k.
                    N/A: 77, 103, 123, 148, 177, 207, 232, 251, 262, 263, 259
                    100 shot: 166, 190, 209, 232, 259, 287, 312, 317, 293, 295, 290
                    • TGP37
                      Shadetree Engineer
                      • Jul 2011
                      • 1027
                      #250
                      Dude, your car is sweet! I can appreciate the detail in numbers.
                        Thanks, its been a project getting it to where it is now... and still is a project... LOL
                        • TGP37
                          Shadetree Engineer
                          • Jul 2011
                          • 1027
                          #252
                          Yeah, same here. I started this turbo build of mine 3 years ago. Lots of time working out the bugs resulting from custom engineering stuff.
                          Once I get the car running near flawlessly w/ a tune superior to factory....I'll be starting the mods for high boost. Even considered drilling out the plenum barb fittings for air tight flared fittings. I plumbed stainless steel vac lines and love it. But all in due time. I got to work the manual in some first. Get the clutch broke in and tweek the PCM.
                          I finally got the heated garage ready for winter. Now I can work in warmth while it snows.
                            I have heat in my garage but its not insulated so I need to warm it up before I head out there... Kinda sucks, I wanted to get some insulation in it this summer and fall, but time just hasn't permitted that to happen... same with funds... Oh well... If I get down time in the winter I can always throw some stuff up.
                              Responce from TCIauto's contact website....
                              We don’t do anything with transaxles unfortunately. You will want to contact PATC 1-888-877-1008 or www.transmissioncenter.net
                              - Don Mudrich
                              TCI Email & Live Chat Sales/Technical Support
                              TCI Automotive
                              151 Industrial Rd
                              Ashland, MS, USA 38603
                              1-901-375-3483 (my direct line @ Comp Cams) 8 AM to 5 PM CST Monday thru Friday
                              1-888-776-9824 (TCI main line)
                              1-662-224-8255 (TCI fax line)
                              www.tciauto.com
                              dmudrich@tciauto.com
                              *If you are replying back to this email, please retain all previous text originally sent.
                              Sent: Monday, October 24, 2011 11:06 AM
                              To: tech2
                              Subject: TCI Tech Support - Jonathan Chmura
                              Message sent to TCI Tech Support
                              Sender Name: Jonathan Chmura
                              Email: jpchmura@att.net
                              Message: I’m looking to get a new torque converter for my setup and I’m trying to find the best option. I’m currently running a PDQ converter but I’m not that impressed with it. I’ve been told its tweaked to around 3195 stall yet when I leave the line I’m at 3800RPM + and on my shifts from 1st to 2nd I’ll go from 6500 rpm down to 4818 rpm when I’m not spraying… When I’m spraying I have an RPM range of 5100-6700 that’s it. My final drive gear ratios are 10.71:1 for first and 5.75:1 for second. If you ask me the RPM drop doesn’t seem like it’s enough for a converter that should be stalling around 3200. This is in a 1996 Beretta with a heavily modified motor 4t60e transmission running on a 100 shot of nitrous. Cam specs are 216/240@.050 duration .517/.568 lift 112LSA this is on a 60 degree V6 engine 3.4L displacement with a 3.5L top end on it. I’ve currently put down a 12.67@107 last year but the tires were spinning so much I know it can be better. I was wondering if you could make anything for my application, I know you list OEM Replacements for the 4t60e and 4t65e, and what it would cost. My converter is a 10" Diameter, 27 Spline, .824" pilot, 9 1/2" Bolt Circle, it also has a TCC lockup clutch that I would like to keep intact. If you like to start with cores first, a FAFB converter for a 4t60e FWD application is a 2795 stall to start, and it comes with the lockup clutch I want to have. Let me know if there is anything you can do for me and what this would run me. Jonathan Chmura
                              Sent PATC an e-mail, but it's looking like RevMax has the best price and has responded as the most educated so far.
                              • TGP37
                                Shadetree Engineer
                                • Jul 2011
                                • 1027
                                #255
                                Sometimes I found a brisk chill motivated me to get the job done quicker. lol
