96 Beretta Project
    Originally posted by unchained01 View Post
    Not bad , maybe a brace from the far left upper valve cove bolt to the underside of the coil pak for support and vibration
    Yeah i was going to have two posts go down to where the stock coil bracket mounts.
    • TGP37
      Shadetree Engineer
      • Jul 2011
      • 1027
      #347
      That is one nice flare kit!
      I see what you mean about the rusted #1 post, lol, how the heck did that happen?
        No clue, I thought I got grease on all of them but who knows maybe I missed it or something.
          So slight dilemma... I guess you could call it. Spoke with the guy who got me all my direct port stuff and he informed me that having all the supply lines be equal length really isnt that necessary... SO the question is do I re-do the lines to make them straighter and more direct, or do I just leave them the way they are because they look sweet...
          I also made my coil bracket last night so that should be all set.
          • onefastV6
            • Sep 2005
            • 880
            #350
            I would keep them equal length.
            The coil pack bracket turned out great, nice work.
            2000 Grand Am GT
            2011 Chevy Impala
              That's what I was leaning toward, they are all 8.25" long and then I was going to ensure that the lines leaving the solenoids were also the same length to each block... I want to eliminate any oddness of the distribution and I think this is the best way to do so. Obviously there is no way to make the fuel and Nitrous delivery happen at exactly the same time unless I figure out how fast the Nitrous flows at 950 psi vs the fuel at 63 psi and then get a ratio and shorten that supply system to compensate... LOL way too much if you ask me.
              I'll just put a fuel purge switch on it and hold the throttle open a tad and tap the switch to purge the fuel side of things. I think the slight lean spot I saw on my last runs with my setup were due to the supply line for the fuel being quite long and near some heat so it probably would evaporate in the line leaving air, and then of course you purge the Nitrous side of things so that is there and ready to go.
              • Nick-G
                11's or Bust...
                • Feb 2008
                • 224
                #352
                They look great just the way they are I wouldn't change a thing.
                BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
                  Coil bracket fits under the hood...
                    Live life 3.7mi at a time
                    • 4555
                    #354
                    Enjoying the new welder, I see
                      Yes I am... It's so nice to have the welder so I can just create something when I need it and I can get good welds with it too. Worst part is I have no material to work with so I have to think about it and then go buy stuff... I need to just order a bunch of various sections just to have some things on hand since I know I will be using it often.
                      • TGP37
                        Shadetree Engineer
                        • Jul 2011
                        • 1027
                        #356
                        Yeah, I went out a bought a bunch of steel items when I got my Tig.
                        Washers, rods, plates, tubes, ........all the small items that are inexpensive. I just need to source the bulk of most projects.
                        I often looked at my wifes steel kitchen ware thinking Hmmmm, nah. Not worth the ass whoopin.
                        There is a ton of steel all around ready to be used. But then I do live in steel city, Pittsburgh full of Rust and Funeral Homes. Ugggh
                        Recently I cut all kinds of scrap off a dead washer and 2 steel shelves. The washer made a great source for 2'x2' thin steel plate.
                          Just ordered a set of Teflon 350 cam bearings... Hopefully these last this time. The ones I have look decent but there is one spot on one where it looks like it took too much pressure and started to flake apart... I can't understand why though, the rest look fine. If this teflon set gives me any issues then I think I'll have to have the block checked and ensure the cam journals are straight.
                          Timing chain was dead though... Gears looked fine.
                          You could hear this outside the vehicle when it would idle... Not a whole lot of extra play in the cam to the crank, but just NOISY!
                          Time to get them coated for real
                          Motor coming apart.
                          Been a while since it's been like this... over 2yrs since I redid the bearings in the motor at least...
                          • young gun
                            • Jul 2010
                            • 250
                            #358
                            I love pictures. lol. Did you just use some spray can "sealer" on the headers before?
                              No, it was actually a DIY ceramic coating, but unfortunately I don't have a oven large enough to bake them so I relied on the baking when the vehicle is run, which is a bit unreliable... I also tried to seal coat the front one and that burnt off because it wasn't quite dry enough. If I had the oven to do it in I think they would have baked on fine and lasted but engine heat is just too inconsistent and sometimes too hot.
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #360
                                I want to coat the hotside on the Fiero, but right now, it's not in the budget or timeframe...
                                what all are you going to do to the engine while you have it out?
