96 Beretta Project
    Nice!
    Can you get a side shot showing the back of the hood in relation to the cowl/windshield?
    It almost looks like your scoop is different than the one i got.
    Thanks
    • torq455
      If I only had money!!!
      • 1615
      #32
      like the photoshop on the last one. i should do that! lol BE SURE to give all part numbers and prices so i know how much to save up for. can't wait to see the brake swap in progress. exciting stuff man!! love how the piping into the intake looks. there's a theory that the cobalt SS's brakes will work up front too.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • Barry
        95 Beretta LG8 Action
        • Aug 2007
        • 269
        #33
        Cobalts have a GAY sabb bolt pattern, like 5/110 or something.
        His hood is a full fiberglass hood, not a molded in scoop. Made by US body.
        95 Beretta- Lg8 Daily Driver
          Yes, i know. I have the scoop section from the same hood.
            Your scoop is the same as mine, I didn't get a pic but looking at this you have the same angle at the back.
            That looks pretty good too btw!
            Whoring up my thread with your 13 sec beast of fury... LMAO!
            • Barry
              • Aug 2007
              • 269
              #36
              Edit: DIdnt hit v6z24 before posting...
                Starting work Saturday
                Side by side projects
                3400
                Mini
                Trans out.
                Converter
                Trans in
                Brakes in
                Side by side comparison
                Need to hybridize axles
                Monday Update
                Haven't driven it much at all, just up the road and back to make sure all is well. Need to schedule an alignment soon... so I can drive it.
                Picked up my rear neon brackets today, I'll post pics of those later.
                • mfuller
                  Mr. Common Sense
                  • Nov 2003
                  • 374
                  #38
                  Very nice, but what's with the swiss-cheese action on the front rotors? Or is that just a wheel spacer? I can't tell.....
                  Matt
                    Those are my ultra light weight .58" thick wheel spacers they weighed in at 1.1lbs each when done, and I was like F that... I doubled the 5x115 pattern then added a 10x100 one at 3/4" and a 20x135 pattern at .358" to lighten them up... Ended up at .65lbs each after I got done.
                    • mfuller
                      Mr. Common Sense
                      • Nov 2003
                      • 374
                      #40
                      And you are still hub-centric on your wheels, right? Or are the wheel studs now supporting the weight of the car?
                      Matt
                      • torq455
                        • 1615
                        #41
                        losing just over a 1/2 pound on unsprung weight won't affect much, and you certainly won't feel it. why work that hard?
                        Andy
                        • torq455
                          • 1615
                          #42
                          the studs don't support the weight. they clamp the hub of the wheel to the bearing assembly, and that's what holds the weight. studs can handle being pulled on, but not flexed.
                          Andy
                          • mfuller
                            Mr. Common Sense
                            • Nov 2003
                            • 374
                            #43
                            I realize that. I am wondering that with .58" thick spacers, is the centerbore of the wheel no longer on the hub? Of course using the wheel studs to support the weight of the car is a no-no.
                            Matt
                              Hubcentric before? No, Hubcentric now, YES. I had them made to be hubcentric, before my bearings were too small to do the job and I never got rings made.
                              Also weight wise, when your adding a bunch of weight up front if you can shave off 1lb then that's 1 less pound that I'm trying to spin... they don't make 2 piece rotors with aluminum center hats for no reason. Also it wasn't much work... Hole pattern program on a Bridgeport did all the math and positioning... only effort was pushing the lever down to drill a hole.
                              This is the same upgrade all the j-body guys are doing, it was just done on a L-body.
                                A few more updates.
                                The Neon Rear disc swap found on J-body.org
                                Fitting everything.
                                Bolted up
                                Line adapters
                                Line routing
                                Just need to reconnect e-brake cable, adjust it, and then go to bleeding the system. While I was there I also put my steel braided lines up front to finish that swap off.
                                Don't worry Ben... Nitrous times and vids are hopefully coming soon... Our Beretta meet has unfortunately been hacked down to a 1/8th mile track, so I may have to go before. But I will get Dyno numbers... Mine may not show up as what its capable of thou since I have conformation, the converter I put in is a 3195 stall converter, so that may play with my dyno numbers.
