LED Conversions...Must see
  • HotSauce6226
    • Feb 2009
    • 20
    This is what I do over at NAIOA.com
    Stock is greenish..
    Pics of different conversions:
    Steering Wheel Red:
    My Interior:
    HVAC Blue LED with Red indictators:
    With A/C on:
    More Interior:
    Door Lock:
    Dimmer not installed:
    Dimmer Installed:
    Main Window Control:
    BBE Cluster:
    Window Control Red:
    Back seat LED conversion:
    With the back doors open:
    Trac Control:
    Fog indicator off:
    Fog Indicator on:
    Did this for my girlfriend's 99 Eclipse GST. This was alot of fun..
    Before..Orange
    Now..
    Turn signal is actually pink but didnt come out too good..
    What you think?
  • black00gt1
    BoosT!!!!!
    • Dec 2008
    • 30
    looks good what lights ya use,maybe a how to?
    • 3100 MPFI
      • 1522
      What he said. Also, where do you get your lights from?
      Taylor
      1998 Lincoln Mark VIII
      • HotSauce6226
        • Feb 2009
        • 20
        Lights from Hong Kong. A how to, its different on different cars
        • 93grandprixse
          • Aug 2005
          • 35
          just curiouse, what size resistors did you use?
          • HotSauce6226
            • Feb 2009
            • 20
            I used a 620 ohm resistor. Seems to work great for me. The Eclipse cluster was different than the Impala window controls but I used the same stuff
            • kyobukan
              5 SPD Z34
              • Jul 2007
              • 73
              how long does it take to do 1 car?
              • HotSauce6226
                • Feb 2009
                • 20
                That depends. What kind of car and what all i have to do
                • kyobukan
                  5 SPD Z34
                  • Jul 2007
                  • 73
                  what is the most hours you spent on 1 car then?
                  • HotSauce6226
                    • Feb 2009
                    • 20
                    Are you serious? Is this a joke
                    It all depends. The Eclipse cluster 3 hours
                    Impala...Hell who knows ive done all the lights in that car
                      He was simply asking for a rough estimate, to see if this is a job that a cluster can be done in about an hour or so... and overall time invested to get the results you have. Its a way to tell if its worth the time to go and upgrade all of the lights in your own car.
                      Knowing that it took you 3 hours on the cluster means this is something that I would be willing to do on my own car... The question I have concerning some of your colors tho, is how did you split the color on the tach of the Eclipse.. did you cut the plastic illumination bar and then paint over the ends and illuminate the high RPM area by just using a different LED? Also about how many LED's are in that cluster?
                      • HotSauce6226
                        • Feb 2009
                        • 20
                        He said nothing about a cluster. He said 1 car. Well on the impala i do various parts on it. So can A cluster be done in an hour..no. So unless he said the cluster i would know. The impala cluster will take longer than the eclipse so that doesnt justify how long it will take for his car.
                        To answer your questions: What do you mean split the color of the tach? The tach was lit up with 3 white LEDs. I didnt cut a bar or paint anything. I had to sand the orange off the back of the gauges so that white showed thru not orange. Total LEDs 3 for the speedo 3 for the tach, 2 for the boost 2 for the other gauge and 1 per on each other indicator, like turn signals, seat belts ect.
