Help ID Engine
  • QuickSilver
    • Apr 2010
    • 5
    Help ID Engine
    Greetings and salutations. I come in peace and I bring you good tidings.
    I am working on a swap. I have a 69 or so MGB with a GM V6 engine.
    I need help in identifying this engine. I am hoping it's a 3.4.
    What information can I provide you Guys to help me? The only number I can readily see is 061L / 3
    Here are some pics
    I hope to have the engine and trans out this weekend to hopefully start the rebuild if it's a 3.4
    i don't suppose you could find the VIN number on the block?
    • QuickSilver
      • Apr 2010
      • 5
      Hey, that was fast, thanks Man. Where do I find this number?
        it SHOULD be near the starter.
        if i had to venture a guess though, based on the numbers from the side of the block, it sounds like a 2.8, and an old one at that...
          if you manage to find a string of numbers, try searching them in here:
          MEME4D membuat academy profesional khusus situs toto online eksekutif dengan reputasi paling berharga di Indonesia, tersedia variasi pasaran terlengkap dengan keluaran tercepat.
          F-body 3.4 motors had block casting numbers of 11018608 and 24504089.
          • QuickSilver
            • Apr 2010
            • 5
            I see. It is an old conversion so it could very well be an old type.
            The conversion kit can use up to the 3.4L engine (60 degrees), is this still a decent engine with decent power or should I instead look for a 3.4 which is the highest horsepower 60%
              for a simple upgrade, yes a 3.4 from either a 93-95 camaro or firebird would be your best bet.
