After 3 years of darkness, it finally sees daylight......
    • 9188
    Looks like it was introduced in 79 as an 80 model...
    Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
    • RebelGT
      • 642
      lifting the rear wheel in a turn is not a sign of bad suspension, its showing good weight transfer to the appropiate wheels, GRM did a nice write up on this a couple issues back on setting up FWD cars for racing.
      26+6=1
      • Rhedalert
        Dr. Feelgood
        • 1574
        Love it! My mom had a '81 Citation 2/dr hatch in gold bought new. Wish she'd have kept it around!
        Brian
        3400 SFI V6, 4T60e
        • Doubt_Incarnate
          I still watch ROBOTECH!
          • Jan 2005
          • 1130
          i didnt mean anything mean. i just figured if you put the time and money into something you'd make it look good the whole way around. it is funny when a chump gets beat something that looks $500, especialy if its a imort tuner car. makes your car like a super sleeper. you did a great job, better than i probably will. so what is the setup in there anyways?
          • RacerX11
            • 1060
            I will have to check out that article. Do you know what month it was, or if it is available online? In my experience, any time you lift a wheel, it is bad. Any time a tire is not in contact with the ground, it is not providing any grip. You can achieve good weight transfer without lifting a tire, it is just harder on nose-heavy FWD cars. It is an issue with the front roll stiffness being much softer than the rear which results in the rear wheel lifting. This roll stiffness imbalance is usually required to keep the FWD from understeering so bad. I have pushed as much weight to the rear of the car as possible to help counteract this.
            I'm not saying this is right, I just know it works for my car.
            Marty
            '99 Z-28 - Weekend Driver
            '84 X-11 - Time and Money Pit
            Quote of the week:
            Originally posted by Aaron
            • RacerX11
              • 1060
              #21
              $500? Heck, I only paid $150 for the car I know you didn't mean anything by it..don't worry about it.
              The engine is a 3.1/3.4/3400 hybrid. The short block is a ?91 3.1 block bored to 3.625?, with a ?99 3100 crank, modified 327 rods, and Venolia forged pistons @9.4:1 CR. Rings are Hastings moly-coated high tensile iron from a Holden V6 race application. The rotating assembly has been balanced. The cam is a PAW grind, very close in specs to the H260. Heads are mildly ported ?99 3100 piece with gen2 pushrod guide plates, gen1 rocker studs, and Comp 1.6 roller tip rockers. Intakes are port-matched 3400 units, with the plenum ported out to match the 65mm TB and adapter plate. Headers are custom equal-length, 1-5/8?x26? primaries, 2-1/2? collectors. ECU is Haltech E6GM. Flywheel is 8lb. Fidanza aluminum. Clutch is currently Perfection HD unit, soon to be replaced with ClutchNet 6-puck.
              I built the engine to be supercharged, so after the break-in period it will receive some boost via an M90 form a T-Bird. The alternator has been re-located to where the AC compressor used to reside to make room for the SC above the rear valve cover.
              Marty
              Quote of the week:
              • Doubt_Incarnate
                • Jan 2005
                • 1130
                #22
                sweet!
                how do the cylinder walls look? are they still an acceptable thickness? i always figured boring the 3.1's out that far would be risky, let us know how that overbore works out. i have the same block, and since there isnt much replacement for displacment, i'd be willing to go the same route. that should be a monster without boost, that SC gonna make a hairy fwd.
                • RacerX11
                  • 1060
                  #23
                  I thrashed this same block at a 3.622" bore for three years with iron heads, DOHC pistons, and roughly a 10:1 CR with no problems. Before we bored it the first time, we checked the block for core shift, and they were all pretty much dead on. According to the specs, the nominal wall thickness was 4.5mm, so they should be around 3mm thinck now. I have never sonic checked them to see, however. I figure if it is going to fail, the boost will do it. I have a spare 3400 short block waiting as a spare just in case. I plan to hit 300WHP or blow it up trying. With the LSD, and a modified Getrag jackshaft, I am hoping to quell some of the torque steer inherent with a FWD with this much power. We shall see how well it works.
                  Marty
                  Quote of the week:
                  • Doubt_Incarnate
                    • Jan 2005
                    • 1130
                    #24
                    so you got 3 years of hard drivin' N/A. i don't drive real hard so i think i might have to look into that. be interesting to see how the block fares under boost.
                    • RebelGT
                      • 642
                      #25
                      it was in this issue, if i remember right,
                      26+6=1
                      • RebelGT
                        • 642
                        #26
                        I double checked this morning, it was in that issue, and I was correct. They even high light the lifting of the inside rear wheel on the cover shot of the article. They said that when the rear wheel is lifted it shows maximum weight distribution to the proper wheels and that the car is not in a state of understeer.
                        26+6=1
                        • Kyles93Z34
                          • Dec 2004
                          • 347
                          #27
                          The X-11 kinda looks like a cavalier hatchback i think. Are they baiscally the same thing? Thx
                          Kyle
                          1992 Lumina Z34
                          5 Speed
                          Autozone civic intake
                          Ultra White lights
                          FFP Dogbone mount
                          125k miles
                          2.5 inch Magnaflow catback from Magnaflow cat
                          60degreeV6.com Custom Chip
                          • Quinky
                            • May 2004
                            • 159
                            #28
                            nice job..looks good.. got any pics of the headers and the collectors?
                            • RacerX11
                              • 1060
                              #29
                              Kyle
                              They are both hatchies, so very similar design, but different platforms (X and J).
                              Marty
                              Quote of the week:
                              • RacerX11
                                • 1060
                                #30
                                Here are a couple shots of the headers installed my old iron-head engine. I don't think I have any with the headers unwrapped. I have some better pics on my home computer.
                                Marty
                                Quote of the week:
