Miata with 3.4l
  • evilmiata
    • Nov 2003
    • 156
    Miata with 3.4l
    I had this in the pushrod performance for a few minutes, and then feared the mods.
  • RacerX11
    • 1060
    I hate to burst your bubble, but the guy who hogged out the intake runners on those heads messed up. The stock iron heads have a vane in the floor of the runner to direct flow more smoothly to the intake valve. Most people want to remove it when porting, but according to the GM performance literature, the vane actually increases flow by 17%.
    I love the car, though. I have always wanted to play around with a Miata with some real power. I figured the 2.5 DOHC Probe/MX-6 engine would make a nice swap (then you could stay in SM2 nstead of being bumped into EM for the Chevy engine). Do you have any plans to beef up the rearend?
    Keep us updated on the pogress.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
    • evilmiata
      • Nov 2003
      • 156
      The vanes are in the lower intake manifold. I know about those and kept them.
      There are two problems with the mazda 2.5 DOHC V6.
      #1 The engine is designed to sit canted. If one tried to stand the motor on-end like a proper RWD configuration, the engine would be oil-starved. It is possible to run a dry sump ($$$) but....
      #2 There simply isn't a DOHC V6 out there that will fit in the engine bay of the miata.
      As I mentioned on the site, the rear-end has already been beefed up: RX-7 Turbo II. This is the 8" rear clutch-type LSD found on second generation turbo RX-7s. It will handle a lot more power than I'll ever be able to milk out of the 3.4l. The half shafts are a custom job comprising of an RX-7 inside spline, Mitsubishi shaft, and 323 GTX wheel spline.
      As for autocross, I could spin the Victoracers at will with the turbo. I wouldn't mind trading them in for a nice set of 9" wheels with sticky Hoosier slicks for EM.
      • DEI37
        • Jan 2004
        • 516
        What I'm trying to figure out is that it's got a carb on it, and then you mention a LT1 throttle body and injectors. I assume it's being turned into a MPFI/SFI engine?
        • 614streets
          • 344
          Hey very neat keep us posted on how it ends up.
          1992 Chevrolet S10
          2.8 v6 tbi 5 speed
          • RacerX11
            • 1060
            I think the carb was on the engine in its previous vehicle. The Miata will be getting EFI.
            Marty
            Quote of the week:
            • 614streets
              • 344
              what manifold is on it edelbrock?
              1992 Chevrolet S10
              2.8 v6 tbi 5 speed
              • evilmiata
                • Nov 2003
                • 156
                As the website mentioned, the previous owner intended to use a carb. Since I want to reuse the Haltech, I'm adding the intake manifolds and fuel rail from a '94 camaro.
                Yesterday I machined the throttle body neck off of the manifold, fabricated a mounting plate for the LT1 throttle body, and milled some delrin spacers for the RC Engineering 550 injectors. I also finished porting the intake manifolds and gave them one final bead blast.
                • evilmiata
                  • Nov 2003
                  • 156
                  Now with page 2!
                  • evilmiata
                    • Nov 2003
                    • 156
                    Update! http://www.cardomain.com/memberpage/487571/3
                    The 3.4l engine test-fitted in the Miata for the first time! My car domain site is primarily a logbook used to share ideas and information with other Miata conversions (5.0s in particular), so other people may wonder why I posted some of my thoughts.
                    • RacerX11
                      • 1060
                      Looking good!! You are getting me thinking about finding Miata in need of a heart transplant
                      There was a smaller starter available on the later 3100/3400 engines. The problem is this starter would bolt on the driver's side of the engine in this install. If you could find one of the duoble-starter T5 bellhousings, it might work and give you the necessary clearance btween the unibody and starter without cutting.
                      Marty
                      Quote of the week:
                      • Cliff8928
                        • 532
                        you can most likely use a Small-Block Chevy starter if you need it to mount on the passenger side...
                        Cliff Scott
                        89 BerettaGT
                        89 Volvo740
                        Cliff Scott
                        89 BerettaGT
                        04 AleroGX
                        • v6h.o.
                          • 1418
                          damn thats going to be sweet when your done.
                          yes like cliff said the SBC's used a small starter much like the 3400/3100 used.
                          does it have the proper # of gear teeth Cliff?
                          Colin
                          • Cliff8928
                            • 532
                            Don't know on the gear teeth, i never had a use for that... Then you'll need to make sure it's the correct bolt pattern (with the in-line holes)
                            From what I've seen, the smaller FWD starter (like on the 3400s, etc) will work on my Pontiac V8
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            65 GTO
                            Cliff Scott
                            89 BerettaGT
                            04 AleroGX
                            • evilmiata
                              • Nov 2003
                              • 156
                              update
