I had driven the car for a couple months with a spun rod bearing prier to this video.. At one point in the video I was doing aprox. 140-150 in 3rd gear ,my ignition system has a built in limiter at around 9 grand so weather it was that or the on the valves there was somthing that made it not rev any higher.. cant tell ya how high I was reving, wasnt quite paying attention to the tach.
Blew a 2.8L on Video
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian RacecarTags: None
I did its the car/engine in my SignatureOriginally posted by sil View Postpoor poor thing...
now time to build sommin that can take the abuse mwahhaVIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Nice destruction, but you never got close to 7000 RPM in that video, let alone 9000 RPM. Hearing the engine tells me that much anyway. I'm also assuming 140-150 is KM per hour, since no GM car can manage 140 MPH in third. Looks like it ran on 5 cylinders for a bit though, which is impressive.I may own a GTO now, but I'm still a 60V6er at heart.
it looks like aluminum heads, with a carb. did you find some ultra rare once-upon-a-time race part or make your own intake?If you aren't friends with a liar, you aren't friends with anyone.
You don't think so? I've seen 141mph in 3rd gear. Turns about 5700rpm.Originally posted by OldSkoolGP View PostNice destruction, but you never got close to 7000 RPM in that video, let alone 9000 RPM. Hearing the engine tells me that much anyway. I'm also assuming 140-150 is KM per hour, since no GM car can manage 140 MPH in third. Looks like it ran on 5 cylinders for a bit though, which is impressive.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Input Parameters Are the Following:
Differential Gear = 3.73 to 1
Transmission Gear = 1.49 to 1
Tire Diameter (Inches) = 23.00
Vechicle MPH = 90
Computation Results:
Computed Engine RPM is 7310
My bad, guess I didnt didnt hit 9, and how fast I was going is also tricky kuss I had no spedo, but my buddy in the vehical folowing me was doing 140-150 and he said he wasnt want catching up so I figure 144kph is a safe speed to say. Well next time I will videotape the tach and make sure I show a flash to alteast 8 HAHAHAVIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
My car does 140 in third.Originally posted by OldSkoolGP View PostI'm also assuming 140-150 is KM per hour, since no GM car can manage 140 MPH in third.
3100 MPFI, custom chip, 4T60-E tranny
140 MPH (MILES PER HOUR) @ 6,700 RPM (car shifts at 7K RPM)Taylor
1998 Lincoln Mark VIII
damn... mine will only do 90 in 3rd.. but i could do 160+ in 5th
You got somthing with a v6 to do 160 ,mph??Originally posted by Superdave View Postdamn... mine will only do 90 in 3rd.. but i could do 160+ in 5th
I'd still be amazed to see a street legal V6 do 140+ in third gear and not do some type of damage to the drivetrain or your motor. Unless your gear ratio is set extremely high and you have no bottom end whatsoever. I know I've seen plenty of idiots float out there motors around here trying to show off or race some car they'd never beat, and they'll never run the same afterwards
No, but it's possible... I set my speed limiter at 120 in the chip. When it hits cutoff there is alot more left in it...Originally posted by Ortie666 View PostYou got somthing with a v6 to do 160 ,mph??
I've always said.. untill i hit the limiter in the 1/4 mile i'm not moving it any higher. Besides, i'm switching to a 3.94 GTZ tranny so my theo top speed will drop quite a bit.
I have a feeling i'll be trapping close to it next spring...
