Tires
  • Lyle's GTP
    • Jan 2004
    • 1345
    Tires
    Ok, does any body know if 245 45ZR 18's will fit on a 94' GTP? Next question: These are very expensive tires, but I don't want to dump a $2000.00 on tire's that are going to be garbage in less than two years (the idea seems kind of mute). Continental tires were a fair price, are they any good?
    Lyle
  • blk92z34getrag
    • 515
    They should... I read that someone had 255/45-17's on their Grand Prix without any rubbing problems... but if I were you I'd go with 245/40-18's, I know at least a few people on here have that size without any problems, and that's what I'm gonna go with when I win the lottery.
    --Rob
    • Lyle's GTP
      • Jan 2004
      • 1345
      The only reason I chose that size was because it's the only one that meets the stock diameter.
      Lyle
      • blk92z34getrag
        • 515
        Yeah it is exactly the right diameter... give or take a millimeter... however you may have problems with rubbing, you might need thin spacers. I know I went to my speed shop near me (Speed Merchant) back when I wanted to get 245/50-17's (which would be the same diameter as yours) and they said I would probably have rubbing problem... and there might even be problems with 245/45-17's, though I doubt there would be.
        If I were you, go with 245/40-18's, it's a little smaller diameter, but I don't think the speedo difference is tremendous... you can probably have it recalibrated too.
        --Rob
        • JasonZ34
          • 116
          The speedo will be fine as long as its with in 3% of the stock diamater, according to tirerack. About how the tires will do what kind are they? besides just the brand? There should be a tread rating... that will tell you how long they will last. MY bridgstone Potenzas lasted me a whole year before I had to rotate them, not even actually.
          • Lyle's GTP
            • Jan 2004
            • 1345
            Hey guy's check this rubber out, I found it at Tirerack. Tell me what you think.
            http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
            These are $194.00 USD a tire, I think they are worth it. The suggested retail in canada for these is like $800.00 a tire. So I'm going to have to support the US on this one.
            Check out these reviews at: http://www.1010tires.com/tiresearch.asp
            Type in: 245 45 18 under "tire size"
            Lyle
            • JasonZ34
              • 116
              280 isn't a bad tread wear rating. better then mine were. 220 http://www.tirerack.com/tires/tires....dex=1&vIndex=0
              • Lyle's GTP
                • Jan 2004
                • 1345
                Thanks, but I've sort of got a thing for goodyear tires, plus the specs are close and these are a little cheaper.
                Lyle
                • Cliff8928
                  • 532
                  Lyle
                  Totally they are worth it! I love my F1s =-) (notice my avatar, it came from the tire label)
                  Cliff Scott
                  89 BerettaGT
                  89 Volvo740
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                  • RidgeRunner
                    • 971
                    Ouch... I could about buy some Victoracers for what those F1s cost.
                    60v6's original Jon M.
                    • Cliff8928
                      • 532
                      But i bet those Vitoracers wouldn't last nearly as long, or have as awesome traction in wet weather!
                      Cliff Scott
                      89 BerettaGT
                      89 Volvo740
                      Cliff Scott
                      89 BerettaGT
                      04 AleroGX
                      • Juglenaut
                        • 1130
                        I run 16's with 235 50 series
                        I am back
                        Mechanical/Service Technican
                        • Guest's Avatar
                          i run 10 inch mexican hundred spoke rims vatos..which one of u gots my taco bell essay?
                          • RidgeRunner
                            • 971
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            True dat homeslice.
