Need info on 93 instrument clusters
  • asonofabeach69
    • Dec 2006
    • 9
    Im thinking about getting a new (used) instrument cluster for my car because the speedo doesnt work on mine. Ive seen that there are 2 different ones offered (one for the 3.1 LHO cars and one for the 3.4 LQ1 cars) Is there any difference in the clusters besides where the redline starts on the tach? I dont want to buy the one for a 3.1 car and find out it plugs in different or something. lol (its slighty cheaper then the 3.4)
    1993 Oldsmobile Cutlass Supreme Convertible...K&N Intake, 180 T-stat, magnaflow high flow cat, dynomax mufflers, WOT Chip, 18in black focal rims w/ bridgestone potenza's
    2003 Chevy S-10 LS Crew Cab 4x4
    4.3L V6
  • StEvEzAsYcHo
    • Jul 2004
    • 145
    That is the obvious difference.. Also on the cutty supreme clusters, some are equipped with an oil gauge which measures your PSi, and also one that just measures somewhere between L and H.. If you have an L/H oil gauge, you only have a pressure switch (meaning the thing is simply registering pressure).. IF you have a PSi gauge w/ numbers, then you have the oil pressure sender..
    Oh, and I had an 87 Bonneville.. I like the name you gave it! I called mine the Bananaville..
    90 Chevy Lumina: 3.1L V6; swapping out for TLQ1
    94 Cutty Supreme: 3100 V6
    Soon: Something new?
    • HayesPerformance
      • 783
      They both plug in the same.
      The face plate is the only differance.
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
      • HayesPerformance
        • 783
        Opps, I was refering to a Grand prix.
        Not sure on the olds......
        1991 Grand Prix STE
        3.4 DOHC
        1 of 792 Produced
        Extensive Mods Done
        1991 Lumina Z34
        3.4 DOHC
        Getrag 284 5spd
        1 of 30
