Looking for some all data or SI help
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    My friend is looking for some diagrams for their 2001 Aurora to replace the blower motor in the car. I figured I'd ask here since some of ya have access to it. IIRC, doesn't it require to undo the a/c lines? Therefore causing the vehicle to needed to be recharged?
    • 9191
    Remove the AC lines to just replace the blower motor? Nope. This isn't for an Aurora, but it should be basically the same for any car...
    BLOWER MOTOR REPLACEMENT
    REMOVAL PROCEDURE
    1. Remove the right side instrument panel (IP) insulator.
    2. Reposition the BCM aside.
    3. Disconnect the blower motor electrical connector.
    1. Remove the blower motor retaining screws.
    2. Remove the blower motor and fan assembly.
    INSTALLATION PROCEDURE
    1. Install the blower motor and fan assembly.
    2. Install the blower motor and fan assembly screws. NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the screws to 5 N.m (45 lb in) .
    1. Connect the blower motor electrical connector.
    2. Install the BCM into position.
    3. Install the right side IP insulator.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      You the man, thanks!
        Heh dodge intrepids required loosing a/c pressure to change a heater core. and removing the whole dash. Boo!
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Same for H3's... talk about dedicating a half day to a part. POS suv! FTMFL!
