350hp N/A Fiero, pics!
    Live life 3.7mi at a time
    • 4555
    #46
    Originally posted by latemodelnewbee View Post
    Are you sure about the valve sizes there? stock performance small blocks use 1.94/1.50 or 2.02/1.60 valves and aftermarket goes up to 2.05 and 2.08 for the intake and 2.10 (but the valve was moved over slightly and requires offset rockers) and the exhaust goes up to 1.65. I have seen bigger valves but there where on SB2 head which looks more like a big block than small block.
    You're right 1.65.
    At the size they are now, I would think they would touch if splayed and if they were both even slightly open at the same time. There's only a few thousands between them.
    • latemodelnewbee
      • Jun 2007
      • 227
      #47
      they didn't look splayed, you can run 2.08/1.65 on a normal small block layout. my uncle is running the dart pro 1 heads with 2.08/1.65 valves with no problem and you can't even get your fingernail between the valves. The splayed valve heads aren't just slighty splayed there more so than 60 degree heads, trickflow head are canted slightly but you can still tell easily just by looking at them. well I tried to post some pics but my computer is being an ass.
      68 El camino 454 speed muncie 3.90 posi 12 bolt,
      80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
      60 Impala 2 door hardtop L79-327 T56 4.11 posi.
      83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
      91 Z34 now has a hm284. and belly pan in the works
        • 4555
        #48
        They're no splayed, I stand corrected, sorry about the typo. When in the machining industry, it's amazing your eye can pick up a couple of thousands, never mind .030", lol.
        I can see less than 1/16" at arms length anymore We have endmills ranging from 1/16" to 1.5" in 1/32" increments. O.O
          • 4555
          #49
          He found a 6 speed for a G6 for $400 shipped. It will be going in with the new mods.
          Anybody heard of Clem (has 8-10 Fieros)? That's the guy who helps him with ideas and knowledge about modding his car. The owner of the 327 doesn't even have or go on the internet, lol, but always finds a way to get info.
          • latemodelnewbee
            • Jun 2007
            • 227
            #50
            what kind of power can those G6 six speeds handle, just curious
