Where did my blinker go? HELP!
  • PCGUY112887
    • Feb 2006
    • 1067
    Drove my car to class and back Friday, didn't touch it the rest of the day.
    Today went out and took out the bulbs in the rear left taillight and all of the bolts, I wanted to get the housing out to reseal it since it leaks a bit. I pulled and pulled and finally discovered someone had attached the whole housing to the car with silicone, so I said screw it for now and pushed it back in and bolted her up. I knew I had a reverse bulb and brake light bulb out, so I pull the burnt bulb (reverse) and put all of the rest back in. Check the brakes, lights work fine. Running lights, fine too. I turn on the blinker... nothing.
    Turn the blinker on the other way... nothing. WTF? I hit the flashers, they work fine, all bulbs lighting up in front and back.
    So I wonder around a bit, check the blinker fuse and it's fine. Replace it, still no worky. I put my multimeter to where the blinker fuse goes and I get 12v. So I figure OK it's the flasher module thingy under the dash.
    Replace it, still no blinks. What the HELL? Pull the flasher back off and turn the blinker on (with ignition on) and get the multimeter on it, no voltage no matter what I do at the flasher.
    Replaced the reverse bulb, tested ALL bulbs on the car. ALL work.
    Leads me to believe it's the switch in the stalk, but it doesn't matter how much I play around with the stalk I can't get any blinker action. It worked perfectly fine just earlier.
    Help me! I need to go start tuning but now I have no blinkers!
    SpudFiles
    Theopia
    Enjoy life online.
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    on all w-bodys i owned or saw the turn signal leverinside the column goes bad, so all i do is taje the column apart and do it slow and look for things but the connections on the turn signal lever cam shit has a bad connection which is making no lights light up.
    try pulling the lever down before it clicks and see if it lights up, if not pull the lever back a lil and it sgould go.. if that works its time to repair the turn signal switch.. hope this helps u
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    • pontiacdohc@gmail.com
      Pontiac DOHC
      • Feb 2006
      • 181
      my car does sorda the same thing, two years ago i got pulled over and was issued a reckless driving ticket and i got reallllly pissed off and punched my steering whell since then it moves up and down about an 1/4 of an inch and the theres about an inch and a half play back and forth sorda feels like an Old FORD gearbox ne one have ne ideas what i broke inside or think i need a whole new column
      1997 Chevrolet Camaro 30th Anniversary 5Speed.
      3800 V6 (i know its not a 60degree)
      stock for now
      1993 Special Edtion/GTP
      3.4 DOHC V6 LQ1 SOLD!
      CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
      180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
      VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
      • PCGUY112887
        • Feb 2006
        • 1067
        Wow you must have hit that wheel hard...
        No matter what I do with the switch, it won't turn on. I know what you mean by pressing the switch so it makes contact but doesn't click, but it does no good either way. I know they are prone to go out, but it wouldn't go totally 100% dead overnight would it?
        HERE is what is weird though! Sometimes if I turn on the hazards, all of the lights outside will blink but only the left or right indicator in the dash blinks. If I turn the signal in the direction that isn't blinking, it will start to blink like it should be with the hazards on! If I turn it back off, it stops blinking again. This doesn't happen often, but I've done it about 3 times in the past 2 days, both left and right.
        Is there any way to try to clean the switch contacts or anything without ripping the wheel off?
        SpudFiles
        Theopia
        Enjoy life online.
        • 94GPGTP
          95 Grand Prix GTP
          • Apr 2007
          • 593
          It sounds like there is some major corrosion goin on in that switch... There is nothing you can do to try to avoid taking the wheel off.. If its your first time and you take everything slow it would take about 2 hours or less to get eveything fixed or taken apart, looked at, and back together.. That wheel is coming off no matter what..lol give it a try..
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
          • PCGUY112887
            • Feb 2006
            • 1067
            Well I think I found the issue!
            My hazard button is broken off, apparently if the stub isn't pulled to a certain way it is "slightly on", not enough to turn the hazards on but enough for it to think their on and disable my blinkers.
            I just pulled back the little nub that used to be the hazard button, and they started to work! If I press in on it or back, they stop working, pull back and they work, so far they keep working as long as I don't hit the hazards.
            SpudFiles
            Theopia
            Enjoy life online.
