valley screen?
  • El_Diablo
    STFUniversity
    • 917
    valley screen?
    anyone ever used a lifter valley screen on any engine? im looking into it and i cant find homemade setups anywhere online, kinda sux because im wanting a little insight and inspiration, i also have no idea what epoxy people use
    what are your guys opinions on the subject?
    • 9190
    Welcome to our website! Discover a range of top-quality products and services tailored to meet your needs. Browse through our pages to see how we can add value to your lifestyle. Join us in a seamless shopping experience that combines convenience, affordability, and speed. Explore more with us!
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Use a high temp 2 part epoxy. JB weld will work excellent.
      • 3100 MPFI
        • 1522
        Never heard of that. What does it do?
        Taylor
        1998 Lincoln Mark VIII
        • geoffinbc
          • 5831
          Protects the bottom end should the valvetrain come apart.
          • 3100 MPFI
            • 1522
            ahh. Makes sense.
            Once I start rebuilding my engine, I might look into that further.
            Taylor
              • 9190
              Here is Todd's original post discussing the screens...
              http://www.60degreev6.com/showthread...ghlight=screen
              • El_Diablo
                STFUniversity
                • 917
                i knew i had seen it before but couldn't find anything really, funny that i actually posted on that topic over a year ago, lol
                the only issue is getting the screens to stick because if they come loose they can cause just as much damage as they were meant to stop
                • 3100 MPFI
                  • 1522
                  hmm. My step-dad knows something about welding aluminum. I might ask him for some ideas for something a bit more permanent. Glad I have a spare block to PRACTICE on.
                  Taylor
                  • El_Diablo
                    STFUniversity
                    • 917
                    even when tig'ing there can be splash and so on, i wouldn't really want to weld anything over top of the cam where i couldn't be absolutely sure i got all of the little particles out, even with a junk cam in while welding and washing down after, you cant make sure you got everything
                    • 3100 MPFI
                      • 1522
                      My step-dad did somethings where he had to be certain that stuff did not go down there.
                      I asked him about it, and he said that he could remove the cam and put a shield in there, and weld it, then pull the shield back out.
                      I am going to get a lot more details before I do anything. And trust me..... Before I do this to my GOOD engine, I am going to be certain it is safe to do on my JUNK engine.
                      Taylor
                      • El_Diablo
                        STFUniversity
                        • 917
                        hmmm, just wondering, but has anyone here used "lab metal" before?
                        im interested in maybe using the high temp version...
                        • geldartb
                          The Situation
                          • May 2004
                          • 1994
                          http://www.alvinproducts.com/Products/Products.asp?ID=2
                          see the post by superdave on the 3500 plenum. there were a few good suggestions on welding aluminum.
                          99 Grand Am GT
                          1357 cam 227 233 .050 dur
                          515 515 lift 112 lsa
                          • El_Diablo
                            STFUniversity
                            • 917
                            im trying to stay away from actually welding in the lifter valley, what was suggested there was a brazing rod that required 700 some degree heat and who knows how much that rod would splash and splatter, i would be a lot more comfortable with epoxy
                            • geoffinbc
                              • 5831
                              Well I wouldn't weld it since you are dealing with cast iron. Welding it without proper pre heat and post heat procedures will cause lots of stresses that can lead to cracks. Plus after the pre and post heat you would have to check the block and make sure noting moved from the heat. If it did you would need machining to correct it.
                              If it was an aluminum block I would go for it.
