Caddy 3.5l V6 In a 3rd Gen Cav!!
Tags: None
wow!sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
That's actually an Oldsmobile V6. The Intrigue and the Aurora were the only cars to ever get it.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Right, I thought about editing the topic after I posted, as I put caddy in the title since the shortstar/northstar was in my mind. It's based off the caddy stuff but only used in olds. So it's really an olds design but similar to the caddy stuff.
I wonder if the 3.5l TB would bolt up to a 3500 plenum and what diameter it is? Cable, bracket, iac, tps all look in good spots... looks to be 4 bolt... big...
EDIT: looks like 3 holes to bolt it up. No idea on the diameter though...Last edited by IsaacHayes; 12-26-2007, 12:27 AM.sigpic
I thought that engine was a 60*. I know NOTHING about that engine, though.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
isaac its a 65 i got one floating around my garage. ill see if i can find it to take a pic.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
geldartb: cool!! I thought it looked like 65mm from pictures!! Perfect for 3500 swap you just need an adapter or some creative modding to bolt it up!
How'd you end up with one? Same idea?
A pic of the back side would be good. IIRC it even has vacuum lines you can tap off of it.
yeah i was gonna have an adapter made but then i just went with the tce 65, acutally i was gonna make my own adapter got a peice of 1/2 or 3/4 thick i cant remember peice of aluminum off ebay awhile back. damn crazy ideas in my head.
actually for some odd reason i think i got a couple of them. ill grab it tomorrow when i go down there. all of that stuff is down with the car which is not at my house.
kinda sucks having stuff in 2 different places i cant remember whats wheresigpic
99 Grand Am GT
Heh, I still have a chunk left of my 1x7x5" aluminum from when I made my EGR adapter, but not enough for a TB of course. I have a ton of 3/4 MDF that could work if one were to put in nuts secured really well since you can't tap and screw into it very well. Well maybe if you used drywall screws to screw the TB to the MDF! hahahasigpic
The Intrigues I've driven w/ that 3.5 felt pretty peppy, so that Cavalier should run pretty good.
I have an intrigue with a 3.5L twin cam, it is a nice engine and as soon as the wife lets me I am dropping it is my Euro.
OLDS vin LX5 babystar, shortstar, or northstar v6. it is desinged by Olds produced, inspired by caddy.
It is a premium engine and is hard to find, this engine raised the cost of an intrigue by 3k, parts are expensive and since only a hand full of intrigues and auroras got them numbers are low.
According to WIkI the bore centers are different and doesn't lead to an actual degree.
I have worked on the 3.5 a few times already and it does not appear to be a true 90 degree as the heads sit closer than a 90, I have had a few 3.3L's in my day and this engine is tight in the center similar to 60's.Last edited by Juglenaut; 12-30-2007, 12:23 AM.I am back
Mechanical/Service Technican
