compression??
  • pontiac3100
    • 226
    compression??
    hey i have a friend that has a 94 maxima dohc (190hp/200tq) w 150k miles
    it misses (1 cylinder is misfire) at low rpms but gets up pretty quick.
    we replaced the injectors,coil on plug, spark plugs.
    so we suspect that who ever worked on it replaced the variable valve timing assembly but did'nt set the timing right.
    but all the other cylinders seem fine.
    when you remove the coil plug on the others the idle gets rougher same for when you remove the injector plug....
    can anyone shed some light on this?
    thanks in advance
    1992 nissan maxima se (190hp/205tQ)
  • pontiac3100
    • 226
    anyone?please?
