What do you hate about the 60 Degree V6?
  • Rhedalert
    Dr. Feelgood
    • 1574
    Originally posted by gpse3400 View Post
    GEN3: Lower Intake Gaskets(Now rectifed by FelPro), oil pump drive seal(on early models)
    Don't forget Dorman
    Brian
    3400 SFI V6, 4T60e
    • gpse3400
      • 1460
      Yeah Dorman sells the complete set!...Now I forget does FelPro make the steel gaskets?
      Lorenzo
        Yes felpro was originally the one to offer the steel gaskets. And I thought of the idea before they made them. Glad someone finally did!
        I hate the fact that the 3500 didn't come standard in my 1994 beretta, and that the 3900 wasn't an option!! LMAO
        • gpse3400
          • 1460
          .....I think it's time for me to get another engine to build.....I got that itch again....
          Lorenzo
          • Canyonero
            Plays with Volvos now.
            • Sep 2006
            • 1112
            Found the problem with my other Trooper. Cracked head and burnt valve. Not sure which caused the other. So much for your indestructible iron heads powerdoctor.
              lol, i hate it when that happens..
              • JMo60
                • Oct 2005
                • 300
                #22
                They dont make big horsepower stock
                94 Grand Prix
                • Barry
                  95 Beretta LG8 Action
                  • Aug 2007
                  • 269
                  #23
                  I hate the fact that there is a very small aftermarket.
                  I hate my obd1.5
                  I used to hate taking the coil pack mounting bracket off a 3100, but now its easy.
                  Other than that, i like my car/engine. Its not a f-body though...
                  95 Beretta- Lg8 Daily Driver
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    #24
                    i got that itch with what i was originally gonna build up with my old 3400 block.
                    99 Grand Am GT
                    1357 cam 227 233 .050 dur
                    515 515 lift 112 lsa
                    • jp_grasshopper_007
                      Power Level:1,000,000
                      • Mar 2006
                      • 120
                      #25
                      Originally posted by powerdoctor View Post
                      No external oil passage in a good spot for a dry sump system...
                      Too many oil return holes in the lifter galley causing windage....people make vent tubes
                      No oil return low in the block for turbos or accumulator's....
                      No 4 blot main option....stud it, it's stronger than a factory 4 bolt(you're not removing material from the block for the extra bolts)
                      No welch plugs in the side of block...
                      No cross drilled factory cranks ....take them to a shop and get em drilled
                      No "wall oiling" option on factory rods ....take them to a shop and get em drilled
                      Non adjustable valvetrain, stock aluminum heads..."drill and tap em for 3/8 studs" haha
                      The stock gen3 roller cams/ chains ...roller's better than flat
                      Did I forget anything?
                      because I\'m not Canadian
                      • merlot566jka
                        • Nov 2006
                        • 570
                        #26
                        iron head:
                        lifters, cam bearings, heads and up
                        gen 3 (3500):
                        location of the lower intake to head bolts, coolant setup (doesnt work well for a fiero!), thermostat location, lack of mounting area on the front side (a/c side) of the block, oil filter so close to the a/c, weak timing chain, intake plenum, etc.
                        but i love the 3500!!
                        2012 Chevy Sonic Turbo 6spd
                          #27
                          Why do you not like the 3500 plenum? Better than the 3400 plenum!
                          • ikessky
                            • 614
                            #28
                            I hate how the oil filter screws to the side of the block so that whenever I change the filter, oil spills out and drips down the block. And then theres the wiring for the wheel speed sensors that pass right under the filter so the hot oil that is dripping lands directly on the wires. Other than that, I don't mind the engine.
                            • Canyonero
                              • Sep 2006
                              • 1112
                              #29
                              Yeah, I get oil all over the starter in my Trooper.
                              • merlot566jka
                                • Nov 2006
                                • 570
                                #30
                                well the plenum is huge! id like a dual plenum, look at nissan's 3.0 with dual plenum, fords 4.0sohc, the sho motor, mazdas 1.8l v6, some chrysler 3.5, hell even a kia i worked on had a better intake setup.
                                i think the injectors need to be in the heads (not DI, just placed in the heads) and the intake be made more direct with less curves, with dual plenums, and velocity stacks for each runner.
                                im just going to make one that i want one day!
