I've found a 1988 Fiero GT, white, gray interior, 2.8, auto. My questions are: What are some of the typical problems with the car? It has 100,000 miles on it. How hard is a manual conversion? What would I use? How much harder is a 3.4 TDC to put in than a 3400? The car is all original, going to see it this weekend. Anyway...... lemme know something! Later!
For all the Fiero people.....
1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
1962 Buick Electra 225 STOCK... and gonna keep it that wayTags: None
I've heard that the 3.4L DOHC is one of the easiest swaps to do physically. Only one motor mount needs to be changed. No matter what motor you put in there though, you are going to have to wire it up. I think a 3.4L DOHC/284 combo in a Fiero GT would be a KILLER setup!
Man, I hate having to explain this.
The engine fires were a result of the 2.5 4-cyl engine leaking oil out of the valve cover, plus the engine had oiling problems that would cause the engine to trow a rod, and dumping oil on the converter. The cars are actually designed way ahead of thier time.
The 88's did have a superior suspension, and the manual conversion isn't hard at all, just get the cv shafts from the donor car.It\'s Alive!
It\'s Alive!
