FAST HELP Needed! Gascap Stuck On!
  • PCGUY112887
    • Feb 2006
    • 1067
    I bought a locking gas cap at Autozone a few years ago, it's been working fine. Today I go to get gas and I turn the key to unlock it and I turn the cap, and it's very hard to turn, and it "clicks". I try the key again, lock it, unlock it, still won't come off. I play with it and notice that when I am turning the key the whole key cylinder moves up and down. I have tried pressing on it/pulling on it while unlocking, no luck.
    I have about a gallon of gas left in my tank, Low Fuel light is on, and this cap is stuck!
    HOW DO I GET THIS OFF?!?
    SpudFiles
    Theopia
    Enjoy life online.
    Live life 3.7mi at a time
    • 4555
    Probably going to have to drill it. Sounds like a tumbler is stuck and rotating the entire cylinder.
    • PCGUY112887
      • Feb 2006
      • 1067
      Would the little metal flap under the cap protect from shavings? I called a shop to see if they had any tricks for something like this and they suggested a locksmith since they wouldn't drill on it, said it would end up putting a bunch of shavings in my tank.
      SpudFiles
      Theopia
      Enjoy life online.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        use a torch to get the cap off.....trust me
          • 4555
          Well seeing that the bottom of the cap should be sealed to the tank, you should be fine.
          Otherwise, use a slap hammer and screw the end into the key hole and bang it out. You need to get the cylinder out somehow (like breaking into a trunk).
          I don't know if a torch is a good idea with gas fumes.
          • PCGUY112887
            • Feb 2006
            • 1067
            Well ended up being able to pop the cylinder loose, which in turn made the entire face of the cap rip apart, then used pliers to turn the piece that has the threads in the filler neck and it came off.
            Thanks.
            SpudFiles
            Theopia
            Enjoy life online.
            • Ray Hamilton
              • Feb 2007
              • 239
              Drive a screwdriver into it,opened every time I've did it.
              '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
