Power Door Locks Not Working: W-Body Please Help!
  • jmgtp
    • 1219
    Car:
    1991 Grand Prix GTP
    Power door locks cease to work. They do not work via the switches on the door or the key fob. It has an aftermarket keyless system that replaced the original system and was wired into the original system harness. It has worked flawlessly for years until today. I used the fob to unlock the car, drove about 5 miles, parked and the power locks would not work. All the fuses in the glovebox appear OK as do the ones under hood. What fuse pertains to the door locks? Obviously nothing is labeled "door locks." When I press the button on the door I think I hear the click of a relay underneath the glovebox. Also, the keyless entry 'armed' led light does not light up when I press the arm button nor does the keyless entry trunk release button work. The in-glovebox trunk release button does work. This leads me to believe that the following items have no electricity: power door locks, keyless entry system, power antenna (see below). Everything else seems to work OK including interior lighting, radio, dic, dash, etc.
    2 other very odd coincidences:
    1) Power antenna is stuck up. The power antenna motor does not run. Perhaps related to the power door locks not working? same power source? though since all fuses seem ok maybe this isn't a fuse issue? The antenna in-operation happened at the same time the locks stopped working.
    2) Also, the brake light fuse blew. I replaced the fuse and they work as normal now. I think this may be due to when I got my alignment done the other day. They put some kind of bar to hold the brake pedal down and since they had some problems with the alignment the brakes were applied for well over an hour and probably closer to two. The 15amp fuse looked melted like it got too way too hot. I'm thinking that the brake light fuse was a result of the brake lights being on for two hours and has nothing to do with the power door locks or antenna but thought I would mention it just in case. The fuse may have even blown the other day and I just so happened to notice now. I'm chalking the brake fuse up to pure coincidence.
    sorry this got long but I'm trying to be thorough. Any advice, things to check etc appreciated!
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    if its a aftermaarket system there will be a inline fuse for the power supply for the aftermarket system.. the fuse for the aftermarket system will no be in the factory locations.. your motor for the antenna prob went bad or a possible relay.. Look under the dash by the steering column for your aftermarket fuses
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    • jmgtp
      • 1219
      I installed the aftermarket system. Since I used the power wires that went to the original keyless entry I did not install a fuse on the logic of the power wire I used is already fused.
      Other side note, what tipped me off to the brake lights not working was two things. The first was the obvious one, its night time, and there was no red glow in the rear of the car when I applied the brakes. The second was that any time I did apply the brakes the seatbelt warning light would glow dimmly. Why it glows when the brake light fuse is out is beyond me but I replaced the fuse and the brake lights work and the little guy doesn't glow.
      1994 Corvette
      LT1/ZF6
      3.7/42RLE
      • PCGUY112887
        • Feb 2006
        • 1067
        On mine, it was "Power accessory #2" or something like that, it got blown when they installed my keyless. I took it back to the shop 3 times, for them to tell me it was a "feature" that my lock buttons didn't work now.
        A new fuse there took care of that, and the fact my power mirrors didn't work.
        SpudFiles
        Theopia
        Enjoy life online.
        • jmgtp
          • 1219
          Solved
          60 amp fusible link blown. Why it blew out I don't know. The instant I replaced it the power antenna retracted and my door locks work again.
          1994 Corvette
          LT1/ZF6
          3.7/42RLE
