Engine Torque Mounts
  • DrewZ28
    • Dec 2008
    • 11
    My car seems to break the torque mounts quite often. Is this a common problem? And is there anyone who sells a polyurethane torque mount for a W body?
    Supercharged '97 Camaro Z28
  • wedebrook
    • Jan 2009
    • 6
    if you are referring to the dogbone mounts at the top front of the engine, then yes. they also have offset poly mounts, shorter dogbones, spacers, and poly trans mounts. check out zzp.
    Edit: those are for newer w-bodies, i dont know if they will fit on yours.
    2000 Impala 3400 with some mods
    2005 Trailblazer LS 4.2L Vortec
