2000 la1 camshaft in a 1996 l82 engine
  • technician48658
    • Feb 2009
    • 2
    hi i am wondering if i can use a 2000 la1 camshaft in a 1996 l82 engine and it will run ok?
    • 9190
    Same exact cam, with the exception of the cam sensor trigger. But, your sensor will still pick up the trigger just fine.
    http://60degreev6.com/node/7
    It says to match trigger to sensor, but its not really required..
    • technician48658
      • Feb 2009
      • 2
      2000 la1 camshaft in a 1996 corsica 3.1M l82
      hi will this cam run ok with my 1996 corsica since the camshaft has a different ring on it for the cam sensor. i'm using a 2000 3.4 la1 block with 3.1 heads and intake and my 3.1 cam is no good but the 3.4 cam is good. thanks
        • 9190
        Yes, you will be fine.
