need some help
  • Pheonix_LJ_KID
    • Mar 2009
    • 24
    need some help
    i have my 2.8L v6 out of my 1981 pontiac pheonix LJ and was wondering could i take a crankshaft out of a 3.1L v6 and put it in my motor and are the berings the same size...(i would get new) im just looking for a way to get more hp and tq and not spend alot of money any 1 have any idea.(ill put some pics of my motor up later
    • 9190
    Welcome to the site! Unfortunately, the 81 engines had a small crank journal size, so the 3.1 crank will not fit.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Agreed your going to need a newer block. At least and 87 up one piece seal block.
      • Pheonix_LJ_KID
        • Mar 2009
        • 24
        thanks...and so thats why on http://www.engine-parts.com/GMV6/gm2834stkr.html they dont have my year
        thanks again
        • geoffinbc
          • 5831
          Possibly. However all that is needed is the correct block and everything else bolts up like it would on your stock engine. You can also jump to the larger valve iron heads. You can do all this and no one can ever tell the difference. Just in case you need to pass inspection in your state.
          Its just like small blocks and big blocks. You cannot tell the difference between a 305 and a 350 or a 394 and a 454.
