U-bend Delete, No Cat..
    My Ranger sounds like butt in a pipe after gutting the cat. My 92, not so bad, but it's got an aftermarket mandrel bent exhaust with a resonator in it to keep the raspy-ness down. If you have any raspy or droning sound, gutting the cat is going to make it worse. Besides, the only real reason to gut it is if it's clogged as a temp solution until you can get a new high flow one.
      Originally posted by monte2k View Post
      well my plan is to gut the CAT and just run a straight pipe through it, weld it shut
      I think you missed my point about you gaining absolutely nothing by doing this unless your cat is clogged like a drain with a hair ball in it.
      With a straight pipe through your cat your car will also become obnoxiously loud... You will be surprised at how much a simple chamber will deaden the raspyness of an exhaust.
      • monte2k
        • Nov 2008
        • 31
        Alright, so maybe ill stick with the 40$ USD (should order that now seeing as the CND $ is almost at $0.90 lol) u-bend delete...
          Yeah to give you an idea, this is my car with a cat and edelbrock muffler
          And this is the same exhaust with the cat removed and a full straight pipe in its spot... I put the cat back in shortly after...
          Yes it does sound rather cool, but the Po Po's around here will pull my ass over SO quick for that... and it doesn't help that my tint is 5% all around... FAR from legal for this area.
          I did a flange and ball joint fitting on the cat section since it also has the 3" dump on it, so if I want I can remove that and put in just a cat section alone, but I had just a straight pipe so I tested it to see how much louder it made it.
          • monte2k
            • Nov 2008
            • 31
            Yeah, i might have to give a shot and see... run the straight pipe before gutting it i guess...
            • monte2k
              • Nov 2008
              • 31
              #21
              I know theres quite a bit headers for most of the cars on here... but im having a real hard time finding a set for 6th gen Monte 3.4l... Id like to slowly redo my who exhaust as i dont have a crap load of cash to just dump on it... and starting at the front, working my way back, seems to make the most sense?
                that exhaust sounds badass at idle.... but you really need some vids with it mving as well. and i didn't really notice any change in the tone, but it did seem to be a little louder, but since its running through the computer, i know thats not how it sounds in real life
                  If 6th gen is 2000 to present, then this should fit.
                  http://www.headermania.com/mm5/merch...de=V6HeadersMC
                  And yeah the tone didn't change much but was extremely louder... and droned like a bastard while driving... hell I hit 3k rpm at 75 on the higway (3.69 fdr)... droning is not what I want... LOL
                    i wouldn't expect it to drone with a cam that big... but i guess you can't have everything...
                      Anything drones with a chambered muffler Edelbrock SDT similar design to the flowmasters.
                        with a chambered muffler?
                        guess its a good thing i decided to go with a glasspack...
                        its nice that it sounds like a ferrari when its overruning too.
                          Yeah, Chambers, no packing material, hollow...
                            too complicated...
                            much better...
                            • monte2k
                              • Nov 2008
                              • 31
                              #29
                              3400-95-modified - Thanks man!
                                #30
                                robertisaar : I agree!! I like my UltraFlo Stainless. Straight through, no drone, just rumble!
                                I can't help but think that chambered mufflers rob a lot of power with the turbulence that has to be created inside. I noticed a power increase just removing the resonator, and it is just one chamber... Maybe I have a sensitive butt-dyno? lol I mean we want as little kinks, turns, flattened pipes in our piping, why would we add it back in with a muffler?
