st43
  • st43
    • Jun 2009
    • 4
    st43
    my 91 sunbird 3.1 wil not rev above 2000 rpm have replaced fuelpump and filter tps crank sensor plugs wires plugs ecm cleaned throttle body i am stumped need help cleaned egr valve 5spd car does this in neatrul and in gear
    • 9191
    When in park/neutral, or when driving as well?
    • st43
      • Jun 2009
      • 4
      all the time can't drive down the road
        you can find Jbody specific information here: http://www.v6z24.com/jbodyforum/repa...ooting-f8.html
        is it knocking?
        If i remember right, a jumped timing chain can cause similar problems. might be worth pulling the front cover and having a look.
        • st43
          • Jun 2009
          • 4
          is it knocking?
          no knocking starts right up and idles rather smooth
          • st43
            • Jun 2009
            • 4
            car wont rev
            car wont rev
            • 95SleeperAcheiva
              ArtofOlivia"PocketRocket"
              • Jun 2006
              • 694
              clogged exhaust. disconnect pipe from manifold, and goose it. If it revs your converter is clogged.
              Converters don't just clog and fail.
              Something HAD to break it.
              99% its do to rich mixture.
              Check thermostat, make sure your car is reaching operating temps.
              Check ECT sensor, comp may think car is cold and running too rich trying to achieve operating temps.
              Check for major vacuum leaks, too much air will show lean on o2 and comp will make run rich to compensate.
              If you don't check the above and correct the problem, you'll eat your new converter
