bigger throttlebody
  • 87camaro
    • Sep 2009
    • 3
    bigger throttlebody
    Hi Guys,
    I have a 87 camaro that has a 2.8 that has been converted to 3.4L. I am looking to upgrade the MPFI intake and throttlebody. Does anyone make upgrades for RWD v6 60degree engines?
    Live life 3.7mi at a time
    • 4555
    Best thing to do is swap to the aluminum heads Simply putting a bigger TB on a poor flowing heads won't net you much gain (if any at all).
    I can get you all kinds of parts for your RWD
    • 87camaro
      • Sep 2009
      • 3
      Hey John,
      My understanding is that the alum. heads won't work on the 2.8 RWD motor. The motor has been stroked and bored and have had head work done as well. That is why I'm looking for a better intake system or atleast a bigger throttlebody for the MPFI system
        • 9191
        The heads work just fine, but you have to use the aluminum head intakes as well.
          • 4555
          Only the 3500 and bigger heads won't work on the 2.8 because the chamber is wider than the cylinder bore. 3100 and 3400 top ends work.
          I have seen some guy TIG a TPI TB to the 3.4 upper manifolds, but they are boosted and like mentioned earlier, your intakes and heads are the bottleneck, not the TB.
          Simple test to see if you need a larger TB is to take a vacuum reading before and after the throttle plate. If there is more than 2" vacuum difference, then the TB is a bottleneck.
          • no_doz
            • Sep 2005
            • 912
            x2-definitely get a set of 3x00 heads & intake-its not worth it to mess with the iron heads.
