Okay so after spending a day and a half of testing wires and connecting them, 2 wiring diagrams from Crutchfield and 12volt.com, I have come to the conclusion that wiring an aftermarket stereo into my Grand Prix sucks. My factory harness was cut off and the aftermarket harness was hardwired into the factory wires. I got an old factory plug out of a 93 Pontiac Grand Prix SE, same everything, got a aftermarket harness adapter and wired everything up. Radio comes on and everything, no sound. So I wired my rear speakers directly to the harness, still no sound. Since my GP has 6 speakers, does it have a factory amp that I have to bypass? I know it says on the Crutchfield wiring diagram that I would have to bypass the factory amp with an E5000 relay because its on a floating ground. Any help would be appreciated!
Stereo Wiring Issues
sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!Tags: None
for ground, i always connect to the body of the car with the stereo... and i know my Regal had an amp i had to bypass to get the speakers to work, but the aftermarket harness adapter did that for me... it plugged into the output connector of the amp (not the amp itself but the harness that came OUT of it) there was a second harness that ran up to the stock radio... if i was you i would just run some speaker wire front to back and connect those suckers up straight to the deck. if that doesnt work, you must have problems with the deck itself... use a speaker from an old stereo or something to test the speaker outputs of the aftermarket deck. the speaker wires are white green purple and grey, the negative having the black stripe i think... but it will work (if it does work at all) if you hook the two purple or whatever wires to the two connections on the speaker that you know works.
if no sound, time for a new radio.
Does it have a Bose system? If so, your factory amp is under the rear deck, accessible from the trunk.-60v6's 2nd Jon M.
No it didn't have Bose...might be the radio itself. But I hooked up the relay like it says on Crutchfield and give that a shot. This is what Crutchfield gave me as far as wiring:
FUNCTION PIN WIRE COLOR
Accessory 12 Volt 2 YW
Constant 12 Volt 1 OG
Chassis Ground 6,15 BK (2X)
Power Antenna 3 PK
Remote 3 PK (6-Spkr Only)
Illumination 5 BN
Dimmer 18 GY
Left Front Spkr + 9 TN
Left Front Spkr - 10 GY
Right Front Spkr + 7 L.GN
Right Front Spkr - 8 D.GN
Left Rear Spkr + 11 BN
Left Rear Spkr - 12 YW
Right Rear Spkr + 13 D.BU
Right Rear Spkr - 14 L.BU
*Data Line 17 D.GN
*VF PWM
Dimming Input 4 BN/WT
*DO NOT USE THESE WIRES!
Six-Speaker System Notes: If the car has six speakers, it has an amp that powers the door speakers. Otherwise, the wiring is the same as the four-speaker system. The amp is located behind the left side of the instrument panel. The inputs of the amp are wired in parallel with the front speakers. The amp accepts either a floating or common ground speaker level input. The amp receives all of its power from the power antenna lead, because of this an E5000 relay will be needed to power the amp if an aftermarket receiver is installed.
The relay should be wired as follows:
* Connect terminal 85 to the amp remote wire of the new receiver.
* Connect terminal 86 to the BK wire of the Crutchfield adapter.
* Connect terminal 30 to the RD wire of the Crutchfield adapter.
* Connect terminal 87 to the BU wire of the Crutchfield adapter.
* Tape off terminal 87A of the relay.sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
thats just the door speakers though... it should still have sound on the other speakers, and it sounds like it uses the remote turn on line (to turn on your amps) to turn on the amp. lol
i would simply bypass the amp, fuck it. im not a fan of factory stereos. :P but thats just me
I took apart the stereo, glad I did or I would of just kept playing with my wiring LMAO. Loook like someone tried to re-solder something on it and did a real crappy job of it. Go figure. LOL Anyhow, I'm going to get a 7" flip up LCD. Maybe this will be the end of my stereo problems. BTW, the radio I was talking about was a Pioneer.sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
brand doesnt matter when someone tries to jimmy rig the shit. lol i love pioneer. i think they make a GREAT product and especially the premier series of anything. my subs are pioneer IMPPs and my rear speakers are Premier 6X9s. and love em to death!! my deck is a shit ass audiovox 7" pop out useless pile of shit. ill sell it for $100 when i get a new one, maybe less... lol 2 AV inputs, 2 video outputs (one for front seat and one for rear) lol sub and center channel outputs too. its pretty loaded. just has bad programming and reminds me of a commodore 64.
Mine in my truck happens to be a Pioneer. It came in the truck when I got it. It's detachable face and has custom burned out backlights
I like Pioneer also but I think the guy tried to solder a couple circuits on the board and FAILED bad. Oh well, hey got any pics or specs of that Audiovox screen? Might be interested. And Commadore 64 is the shit. I still have my dad's old one with the big ass floppy disk drive.sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
today i installed an amp and sub in my friends mazda 3. fastest stereo install ive ever done. i had it completed in about 30 mins!! running the power down one side and the RCAs down the other... mind you the second hand amp he had purchased happened to be blown. hahaha thats beside the point
I think Mazdas and Hondas are the easiest IMO for installing anything. Running wires and hiding em are easy enough if you done enough in your time. On most cars, I can get done in 20 min or so.sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!
it was also new enough that everything was snap together... i didnt need a single screw driver to take anything apart! haha
the mark of a "quality" vehicle...Originally posted by SofaKingWeToddDid View Postit was also new enough that everything was snap together... i didnt need a single screw driver to take anything apart! haha
lol say what you will, but thats how EVERYTHING is nowadays... for 99% of the work i do on cars (and i work on cars trucks vans and suvs every day doing various electronic installations and repairs) i dont really need much other than wiring tools. to take things apart to run wires the last car i needed a screw driver on was my lumina!!! haha i cant even honestly remember something that had the step sills screwed down.
Nissan Pathfinder, it was a mid 90s one, like a 94 or something. and i had to install trailer wiring on to it, had to unscrew the panel that runs across where the back door opens to run wires from the right tail light over to the left. thats about it. i work on dodge vehicles most... and can pull an interior out quite quickly... its my favorite part of the job.
